Missing shared library
schiu
2011/11/11 - 10:09
I 've successfully download the custom firmware and able to download apps from android market .But some of the apps fail to download and missing shared library was shown .What does that mean and how to solve the problem Thanks in advance
2011/11/11 - 21:52
Do you have more information about which library are missing ?
Can you give more details about which applications fail to download ?
schiu
2011/11/12 - 13:57
The app is hong kong road snapshot , the error just said missing shared library with no specific detail
LaM
2011/11/15 - 14:44
I did have the same problem with another app (whose name I can't remember)...I think that 10 g2's android has been impoverished...mumble....
bruce
2011/11/21 - 10:43
i have had this problem with 2 apps so far, VIBER and GOOGLE GOGGLES. It gives no information regarding which shared file is missing, and doesn't download the apps.
Deedee Rose
Forum Posts: 17
2011/12/05 - 17:29
Same problem for me.
It seems to centre around those apps that expect to find a calendar service, in my case TV scheduling.
Any solutions welcome.
2011/12/05 - 21:56
I have just tested Viber, I got the following error in adb logcat:
E/PackageManager(   84): Package com.viber.voip requires unavailable shared library com.google.android.maps; failing!
I will check what can be done to fix that problem.
Deedee Rose
Forum Posts: 17
2011/12/06 - 00:00
Apps that I am trying to get working include:
TV Guide UK by TV24
Worldmate
omniphil
2011/12/09 - 00:41
The new Google Currents app give this error too. I have seen it in 2 other applications but I can't remember what they were...
How do we do that logcat thing so we can see the actual error to figure out what library it wants?
And is there a way to add the library manually or will this require a new rom?
Love this tablet now that I have Google Market! 🙂
legion7285
2011/12/10 - 23:31
having the same problem as this with whatsapp messenger, viber and outbreak:zombie survival. these are three apps that i really wanted so i hope there is a way to fix?
also ive noticed there is hardly any space reserved for storing apps, when i bought an 8gb tablet i expected i could fill it with as many apps as i wanted like on ios and use usb or sd for media.
i have lost count of how many times i have been presented with a low space error message when i have 6gb free!!!!
daft
Forum Posts: 64
2011/12/10 - 23:39
You had tons of app space before going to non standard firmware/market. I could hardly believe how many apps I loaded at first, expecially when pushing most to sdcard.
This forum is loaded with discussions on how to increase it now or in the future. It currently involves tradeoff choices too complex to put in this thread so read elsewhere. The simplest way you can buy some (but not a lot) of space is to use titanium backup to push to sdcard (you may not need an sdcard for this, just a directory by that name).
legion7285
2011/12/10 - 23:42
if it had more space before what if i reinstall the standard fw and install market apps by downoading the apk and installing, will that work?
66 Guest(s)
Devices in use: Desktop (59), Phone (7)
