I need help!
Ponchovil
2012/03/02 - 13:36
Hello everyone,
I'm kind of a new one when it comes to tablets.
In a few days time i've learned a lot but i keep have problems when it comes to cleaning space on my tablet.
I've learned that there is not much room on the tablet for installing games, etc... on the 'telephone' directory (it possibly has another name). Like i see it, i have only 200 megabytes of space. I know i can move installed games to the SD card. I've allready done that. But with some games or applications, it just doesn't work. Result: i only have left a few megabyte, so nothing i can do right now.
I've saw in arctools that there is a 'media-tab' where i can look in some system maps.
Is this a function that i can use to clean the system? As i said, i am very new here and i have no idea what i can do right now. Can i make the space bigger? Can i move files and clean some maps?
Please help. I'm very desperate.
Poncho
register
Forum Posts: 84
2012/03/02 - 14:31
look for some system tool that can clean the apps' cache and data on demand
2012/03/02 - 15:55
The 200 mb limitation for applications comes from the manufacturer firmware. It's still lots of space for a normal user. Our Kasty EZ custom firmware, being based on the stock firmware also has this limitation.
If you want to go for a more advanced firmware, you check here, you will get about 1 Gb space with this custom firmware.
Media tab in Arctools feature is not related, it's made to enable or disable file indexing, on a directory basis.
53 Guest(s)
Devices in use: Desktop (49), Phone (4)
jacksonrid
