how to change my dump( root
ludovicb
Forum Posts: 16
2012/06/16 - 14:52
I research how people have made ​​possible the root of arnova10G2 to adapt it to my firmware Lazer A101C, because since I started using the fimware:arn10g2-23-20.zip. I no longer have the option of using GetJar rewards (paid app becomes free for a short period) this application is no longer available with firmware arn10G2( i don't download applications with getjar rewards.
I would like to know how to adapt the firmware ARNOVA 10G2 (root, Increase app store, ..) for my dump
And I will send you my dump files:http://demo2.ovh.net/fr/c33c146dc0280fcce4002c7b753ac7dc/
Thanks Received: 3169
2012/06/19 - 09:10
You need to edit system/build.prop file and change the product model to your Lazer A101C, so GetJar knows you're running A Lazer.
ro.product.model=AN10G2-LZ
You should be able to do that with a text editor on the tablet, with the firmware that has /system mounted as writable, check here http://www.arctablet.com/blog/archos-tablet/arnova-10g2-firmware-update-ext4-market-root-increased-app-storage/
ludovicb
Forum Posts: 16
2012/06/19 - 22:58
yes I modified the file System/build.prop of my tablet, but when I restart it's not change.
And I find other file : /default.prop
ro.product.device=AN10G2
I change this with AN10G2-LZ
but when I restart my tablet, in file it's write the same :
Thanks Received: 264
2012/06/19 - 23:35
did you mounted the system writeble ?
set the permissions ?
ludovicb
Forum Posts: 16
2012/06/20 - 13:23
yes I mounted the file System writable and the permission with ES explorer and a editor text. i modified the files: System/build.prop and /default.prop
when I restart my tablet, the file default.prop returns to its original state:
it does not keep my changes:
ro.product.device=AN10G2-LZ
Please help me
ludovicb
Forum Posts: 16
2012/07/03 - 13:28
I don't change
Please help me
82 Guest(s)
Devices in use: Desktop (69), Phone (12), Tablet (1)
seabra6293
emiliusnotes
abdelouahabido
ble1x
darlaive
bogdushok
Topics: 6011
Members: 260683
