high pitch noise
damo
Kingston upon hull, UK
Forum Posts: 243
2011/12/30 - 10:18
Can anybody just confirm to me I am getting a high pitch
Buzzing sound coming from the side where the USB port
Is. When you hold it to your ear you can hear it. I turn
The speaker volume down and still get the sound. Although
Not really loud if you listen carefully you can hear it.
Can anybody just test there tablet for me please to see
If they can hear anything. Thanks
oldduck
Forum Posts: 21
2011/12/30 - 10:56
Yes, I can hear the high pitch noise if my ear is about 1cm away from the UDB port side.
damo
Forum Posts: 243
2011/12/30 - 11:07
Thank you for that info. Wonder what it is very strange
finless
Stanton, Ca
Forum Posts: 604
2011/12/30 - 12:00
I have pretty good high range hearing and I do not hear it at all.  Hmmmm.... If I did I would take it apart to see whats up 😉
Seriously I do not hear any noise from mine at all.
Bob
damo
Forum Posts: 243
2011/12/30 - 12:11
This is the second one now from arnova because
The first one had battery issues. I hope I don't have to send this one back as well.
If I do I will have to re flash the original firmware
Back on it I presume that would have to be
Done with the rock chip flashing tool from
The admin post ?
2011/12/30 - 12:39
Probably, the stock firmware from the manufacturer being a single consolidated update.img file, not the split files (system.img, boot.img ...) that you can find in finless custom firmware.
finless
Stanton, Ca
Forum Posts: 604
2011/12/30 - 13:20
Yes use the admin tool.  If you just copy over update.img and reboot it will be a NO BOOT....  Read my post about the recovery system and why it cant go back and forth ever using a simple copy update.img.
It requires a eraseIDB to restructure the system which the recovery system cant handle on that level.
Read my post about it if you want to know why,
Bob
kernoman
Forum Posts: 16
2011/12/30 - 13:31
I too hear the noise however it appears to be only when I have the screen brightness set to auto or ver low, turn that off and/or increase the brightness and the sound goes
B
finless
Stanton, Ca
Forum Posts: 604
2011/12/30 - 13:40
B
Hmmm.... I bet it is just a crystal oscillating (screen driver or something) and possibly just vibrating on the circuit board. I bet if you took it apart you could add a dab of silicon and be done with it.
Bob
damo
Forum Posts: 243
2011/12/30 - 15:50
B
I will try that thanks and let you know
damo
Forum Posts: 243
2011/12/30 - 16:07
B
You are right if you turn the tablet to full brightness the sound is gone, and that ws a similar issue I had with an lcd tv.
Can others test this as well please and report back to forum. If obviously, having full brightness of on will have an effect
On battery life
drchips42
Forum Posts: 38
2012/01/03 - 12:25
LOL i knew it was the screen that makes that noise.. mine does, so i put the brightness up full .. and it goes.
Even if the brightness is down to 95% you still get a noise...
odd.
If it at full bright, a: it looks a bit washed out and b : it will kill your battery !!
HTC Desire CM7.1, Arnova 10G2 ( stock rom ) All Google products fully working!!
damo
Forum Posts: 243
2012/01/03 - 13:24
I just took mine back to comet in the uk because of the headphone socket busting also told them
About the noise. They exchanged it no fuss not bad as this is the second one I have had a
Problem with. Just charging it now will let you know later if problem still exists
chrono
2012/01/03 - 14:18
I have the same problem but the sound come from the corner right bottom (screen) and not where the USB port is. It happend only when the screen is on.
The lower brightness to 40% : we hear middle level noise
between 40% to 70% of the brightness : the level of noise is the higest
It decrease from 70% to 99%
higest brightness : the noise stop.
damo
Forum Posts: 243
2012/01/03 - 14:35
All charged noise still there, not taking it back again it is not something that is tat loud and can only here it if I hold tablet to my ear, so guess I am going to live with it.
Just loaded back on Bobs Firmware , market etc and all perfect.
61 Guest(s)
Devices in use: Desktop (53), Phone (8)
jacksonrid
usdown
ibob64
kawi
vetBro
