Flash player question??
sadsack
Forum Posts: 37
2012/03/26 - 02:05
Hi all,
Is there a way of telling what version of flash player is installed on the 10G2 stock, I only ask as I'm sure I can remember seeing a post that said whatever you do don't update to a certain version as it causes a lot of problems. (but for the life of my, I cannot remember what the version number was).
I only ask because don't you need flash player to use BBCI player, and other catchup tv services.
Just wondering if there is a way of creating shortcuts to these services, a bit like the x bar on the ps3?  (Out of curiosity I've just downloaded "Go Launcher 2.70" and wondered if that would do what I wanted.
thanks chaps for any replies.....
Sorry for the noob questions, but I am totally lost as to what to do, for instance If I install the apk for go launcher can i still go back to the original stock look if required. (say for instance her indoors can't get on with Go launcher.....
Thanks Received: 268
2012/03/26 - 08:53
If you install a new launcher you can revert back on the stock whenever you want by uninstaling it (also, on my arnobva 7cg2 when i press the home button, 2 option appears, to select from the go launcher and stock)
If you want shortcuts on your main screen, go in to the menu, chose an aplication, click on it for 2 seconds till(the main screen should pop up,and you can drag and drop`it where you want), and you can move`it on your main screen
Go on this site http://www.playerversion.com/ from arnova to check your flash version.
2012/03/26 - 08:57
You can get the version number for any application by going into Settings / Manage Application, then move to the "All" tab, find your application in the list then click on it. You'll see the version info on the first line.
I don't know how to create a shortcut to the app. version.
If I remember right, Adobe Flash version 11.x and later are currently causing problems on the 10G2, so it's best to keep using an older version 10.3
Cheers
sadsack
Forum Posts: 37
2012/03/26 - 10:38
Thank you globula_neagra & admin for your help, I appreciate both your inputs, at least now I understand what to do.
all the best to you both,
sadsack.
black77
Forum Posts: 12
2012/08/22 - 19:44
i have just done this on the arnova 10 g2 had to go back to the 10.3 flash player the 11. was making the browser close all the time.
70 Guest(s)
Devices in use: Desktop (58), Phone (12)
jacksonrid
