Factory reset on arnova g2
daveb
2012/02/02 - 20:56
Could someone tell me the way to do a factory reset on the 10 g2. I have done one (maybe) and would have expected it to have put the tablet back to the config as straight out of box. When it started up again it had apps that I had installed from appslib which I thought would have been deleted. The so called manual has nothing about this so maybe I am not doing something properly.
Thanx
damo
Kingston upon hull, UK
Forum Posts: 243
2012/02/02 - 21:07
Thanx
You can do a factory reset from within the settings of the tablet, Go to privacy settings/factory reset
daveb
2012/02/02 - 21:22
Thanx all done
67 Guest(s)
Devices in use: Desktop (56), Phone (11)
jacksonrid
