I've tried 3 separate firmware versions plus the Arnovatech original via RocketChip batch tool and RK29Update. The firmware uploads, verifies as expected and the screen displays the firmware update graphic with status text appearing where the corruption lines are normally displayed (as there are no corruption lines on firmware update I don't think that there is a screen issue). When the tablet reboots it then displays the attached image and goes no further. Does anybody have a clue to what's going on or is this tablet junked?
http://www.bizsync.co.uk/BizSync/ebay/adverts/photo.jpg
Cheers,
Rob
Rob,
You get those lines with the 3 firmwares ?
Have you tried EraseIDB button before flashing in RKAndroidTool v1.29 ?
It's a 10 G2 capacitive ? How much storage memory (4 or 8 Gb), when did you buy it ?
Yes, that's right, 3 non standard firmwares and the factory standard from the Arnovatech support page. I've tried the EraselDB button before trying the following update:
Also used EraseLDB then swapped over to RocketChip batch tool in order to recover to the factory original firmware from the Arnovatech support site. No luck whatsoever. The procedure works without fault (I've done quite a few now), but then fails on boot (as pictured). It's a 4MB version that's out of warranty.
Cheers,
Rob
69 Guest(s)
Devices in use: Desktop (57), Phone (12)
jacksonrid
