Default Browser Change
nwhite89
Forum Posts: 21
2011/12/28 - 17:44
I think this is the right place to ask? if not I apologise
But is it possible to change the default browser for the Arnova 10 G2 -- Obviously on the Right >> hand side automatically get the "ootb" browser app link, boxes (to go app screen) and settings.
Was wondering is it possible to change the Default browser for any links you open and to change the app link on the right hand side?
damo
Kingston upon hull, UK
Forum Posts: 243
2011/12/28 - 18:57
As soon as you install another browser and than try to open a link or
Program that needs to open your browser than you will get the
Generic pop up asking which program to use just make sure you tick
First and than select the program to use as default. If that pop up
Does not open than go into manage application find the built in browser
And select clear defaults. I would recommend Winkboat browser or dolphin hd
nwhite89
Forum Posts: 21
2011/12/29 - 12:45
kl thanks 🙂 I've downloaded Dolphin already have that on my iPhone but is there a way to change the icon on the right hand side ?
finless
Stanton, Ca
Forum Posts: 604
2011/12/29 - 16:48
Not stock.  If you really want to customize like that then look at either ADWLauncher or Go Launcher.  I prefer Go Launcher myself.
Bob
nwhite89
Forum Posts: 21
2012/01/03 - 10:16
Thanks Finless, Downloaded GoLauncher and I don't think I will bother with the other one its exactly what I wanted 🙂
Now to install and set it up on all the other Tablets in the house <_< hmmm
gerry
Forum Posts: 71
2012/01/12 - 00:27
Bob
i have this exact set up myself and has made it very user freindly
55 Guest(s)
Devices in use: Desktop (51), Phone (4)
jacksonrid
