2012/01/16
Hello all.
Flashed 10 G2 with Rockchip batch tool as per instructions - prompt said upgrade was successful however the device did not power up after this. Â All drivers were installed and it is still recognised in the Batchtool program (Green box) but after resetting the device does not boot up. Have tried flashing with original firmware from archos with no success.Â
Just stuck as what to do next! The original firmware I tried to flash was Finless one, whether that is relevant. Any advice would be appreciated as to what to do. Thank you!
Adam
2011/12/10
There are 2 flash tools. You should not have flashed my ROM with the RKbatch tool. You need to use the tool I provided with my ROM, the RKAndroid tool (RKUpdate.exe).
The RKBatch tool is for only flashing the stock Arnova ROM update.img.
To go back and forth between my ROM and the stock ROM, you should eraseIDB. If you did not do that it will probably hang like what you are seeing.
Bob
2011/12/10
2011/12/10
2012/01/16
Did erase IDB, then ran your rom and all completed successfully according to RKAndroid tool. Device reset (windows device message) and just won't boot up. Puzzling. Have tried stock and rk batch too with no success. I guess I will have to wait and see if anyone else has this problem!
Regards, Adam
Currently Online: matinf
99 Guest(s)
Devices in use: Desktop (85), Phone (12), Tablet (3)
matinf
floki
orocamora
Ellocojoe
Tonysc17
olegator
