Big strange problems (stuck in boot)
MikeJordy
2011/12/06 - 13:43
Hello i bought a new anova 10g2 8G(igabite) tablet (andoid 2.3)
At first it worked fine
after 3 days its started doing strange things i left in on the power that night to recharge
the next morning it whas not loaded at all then it only wanted to start with the anova linked to the powernet en when it started it shut down itselfs after calibrating the screen
then i try'd the reset button only thing it dos now when i try to turn it on is :
schowing me arnova for 1 1/2 sec then nothing
Is there any way to repear this its a new device
2011/12/06 - 14:25
I recommend that you have a look at the posts on the 2 first (pinned) topics in this Arnova 10 G2 forum, it will give you some details on how to flash a firmware on the device. A more complete tutorial should be published soon.
PS: I have moved this topic in the right Forum (Arnova 10G2) and completed the subject.
MikeJordy
2011/12/06 - 18:13
STrange now i holded the on button for 5 sec and is startet normal i only had about 2 sec to see my background and in the upper left corner (loding internal flach storage) then it strated calibrating when itwhas done is immidiatly shut itselfs down
54 Guest(s)
Devices in use: Desktop (50), Phone (4)
jacksonrid
