Arnova 10G2 make little noise when screen is on. Normal ?
chrono
2012/01/02 - 16:32
Hi Every one !
  I have an Arnova 10G2 and i heard that it make long bip (teeeeeeeeeeeeeeeeeeee...) when the sceen is on.
It happend only when the screen is on. When i turn the screen off it stop.
We can heard it more loudly in the corner right bottom.
I just want to know if that is normal ? because it little annoying.
Thanks for your answear.
2012/01/02 - 16:38
Can you please let us know if your problem is similar to this issue ?
/blog/forum/arnova-10-g2/high-pitch-noise/
Thanks.
chrono
2012/01/02 - 16:52
Thanks.
Thank you for your reply Admin.
I will check if the fact that i increase the brightness will stop the noise (i don't have my arnova here).
Yeah the noise come from the screen but not where the USB port is, it come from the corner right bottom of the screen.
I'll check tonight, thanks.
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/02 - 19:02
Thanks.
With reference to this not had a definitive answer as to whether this is a problem or not, as previously stated the sound does disappear at full brightness. Not an experty but it might be an issue caused by a faulty Backlight Inverter?
chrono
2012/01/03 - 14:08
Thanks.
Yes the probleme is similar to the post you paste but the sound come from the corner right bottom and not where the USB port is.
The lower brightness to 40% : we hear middle level noise
between 40% to 70% of the brightness : the level of noise is the higest
It decrease from 70% to 99%
higest brightness : the noise stop.
56 Guest(s)
Devices in use: Desktop (52), Phone (4)
jacksonrid
