Arnova 10G2 battery won't load if less than 30%
register
Forum Posts: 84
2012/02/09 - 00:02
a number of times the tablet wont switch on if the battery is loaded with less then 30-40%
is this normal or do i have to "condition" the battery a few cycles to full drain?
mobius
Forum Posts: 11
2012/02/09 - 20:25
Mine boots even if the battery is nearly flat, so I don't think its normal for yours to need 30-40%
perhaps if you cycled the battery from dead flat to full a couple of times it might help to reset the battery monitor?
mobius
register
Forum Posts: 84
2012/02/09 - 23:53
yeah i'll try that
53 Guest(s)
Devices in use: Desktop (49), Phone (4)
jacksonrid
