Arnova 10 G2 Tablet - Problems with storage and downloads from Appslib
Related Tags
mick_muff69
2011/12/27 - 13:43
Hi All,
I've recently purchased the Arnova 10 G2 (4GB) Tablet for my son at xmas.  I've tried to download Apps from Appslib but the only responses I get is that it's either failed to connect/under maintenance/not enough memory etc and this is on even the basic of Apps.
I've tried transferring apps from the internal memory on to the SD Card to free space but this still doesn't work??
The preinstalled Apps work perfectly I'd just like to add others to it!!
So my questions are:
1) Is it possible to automatically download apps etc directly to the SD Card rather than the internal memeory
2) Is there anything I can do to resolve the Appslib problem as it really is frustrating considering nothing has been downloaded yet?
Many thanks in advance for any help possible!
Kind Regards
Michael
finless
Stanton, Ca
Forum Posts: 604
2011/12/27 - 16:31
There has been a problem with Appslib for about 4 days now.  See this blog post
/blog/featured/appslib-fails-download-unsuccessful-make-sure-you-have-free-space/
If you cant wait till they get appslib fixed, your best bet is to;
1) Follow these instructions to get Google Market installed.  It's an old version but I can confirm this works.  Read this thread carefully as if when you first login you get an error there is a post that I made in that thread the tells you how to clear data and try again.  Before I rooted my ROM this install always worked for me.
/blog/forum/arnova-10-g2/install-android-market-without-root-on-latest-firmware/
2) Install my rooted ROM and google market 4.3.3 rooted using arctools 0.57.  If you a new to all this, installing my ROM is more demanding as you have to install drivers, flash in recovery mode, etc.
/blog/archos-tablet/arnova-10-g2-improved-custom-firmware-root-app-space/
Bob
138 Guest(s)
Devices in use: Desktop (129), Phone (9)
