2011/12/26
ive just got an arnova 10 g2 but cant get apps from the libary so flashed arn10g2-23-01.zip. Since doing it i can now no longer get online with it?? therefore can still not get on the apps libary. When i boot it i get the white lines scrambles across the screen but i cant use arctools to install andriod market as there is no repair and formatting option in my settings? as in your pics where the repair option is mine has a calibration option? what should i do next? cheers Rick.
If you want to flash again the device, please check here if you want the stock firmware for the Arnova 10 G2:
http://www.arctablet.com/blog/featured/arnova-firmwares-updates/
The latest custom firmware from here may also give you better results than the default or first custom firmware:
http://www.arctablet.com/blog/archos-tablet/arnova-10-g2-improved-custom-firmware-root-app-space/
2011/12/10
rg said
what should i do in your opinion, i can get an internet connection on it at all now, do i need to install arctools seperatley??
The first rooted firmware had a problem with WiFi. DHCP caused constant drops in connection. The only way to fix that on that firmware is to set a static IP address. If you do not know how to do that or what that is, you should go back to stock firmware or go to my firmware which does not have WiFi issues.
Bob
2011/12/26
hi bob, ive managed to get online now, but will i keep loosing connection as you said? also now im online i still cant connect to andriod market which is the only reason i flashed it in the first place. When i try to download it says there are no associated andriod phones with this account? is there a link to another firmware that will work? i appreciate your help, this is my daughters xmas present and she hasnt been able to use it all day, ooops! cheers
2011/12/10
What firmware did you install and how did you install the Market?
If using my firmware then use Arctools 0.57 to install the market. Select 4.3.3 rooted install. Should work no problem. Remember to rreboot after install of the Market from Arctools. A few posts up the Admin posted a link to Arctools 0.57 as with Applib having problems you probably wont be able to download arctools from appslib today.
Bob
2011/12/10
rg said
it was your arn10g2-23-01.zip. link which i flashed. Do you do this first then install arctools 0.57 afterwards. I have just downloaded arctools but it is 0.60, is this incorrect
Thats not my version. Mine is here:
File is ARN10g2-23-1_1.zip
The version you installed was the first rooted (not done by me) and had problems with WiFi, Memory space, and other issues. While you can use it the only way I installed the Market on that was using this process:
/blog/forum/arnova-10-g2/install-android-market-without-root-on-latest-firmware/
Bob
2011/12/10
2011/12/26
ive got it all working now thanks, only problem is the lack of storage, i use up the memory striaght away and ive only downloaded 2 games for it. Is there a link to the latest firmware? i dont know if its worth risking bricking it now ive finally got android market running. I still dont have an micro sd card in it either, whats the biggest card a 10 g2 will take? cheers
2011/12/10
RG, sounds like you ARE NOT on the latest rooted firmware. In fact that was an issue with the first rooted firmware.
Only other thing I will say is get a SDCard... YOU WILL NEED IT if loading games which can be big.
Bob
56 Guest(s)
Devices in use: Desktop (52), Phone (4)
jacksonrid
