Arnova 10 G2 4gb Dead after custom firmware install
arnova 7b
2012/05/25 - 19:43
If the USB can see RK29 device...that means the tablet is in the ready to flash mode
May I suggest to use Windows XP instead of vista of windows 7 to try the flash tool again
baalmoloch
2012/05/30 - 14:52
I have exactly the same problem this morning. I am at a loss. Any idea what I should do? When I flash, I have the message "prepare IDB failed". And the square in the batch tool remains blue whatever I do.
Is it hardware or software?
puppetman
2012/06/23 - 18:36
I've had same problem, but the batch tool turns green and installs the firmware upto 42900 bytes then stops and fails......... I've tried numerous times and it always stops at the  same number of bytes or less!!
Please can someone help?
ultradiv
2012/07/23 - 19:41
ultradiv said
Yep got an RMA number and sending it back for replacement
Now got the replacement tablet direct from Archos Smile - cool dudes Cool
The old saying "once bitten twice shy" is applying to my situation.
I have been re-reading all the forum here and starting to think about having another go but I will be a true fool Embarassed if it dead bricks my machine again right? Cry
What think you?  Confused
2012/07/23 - 19:48
The EZ firmware from the link you pointed is a very simple firmware to install, it has been downloaded (and I supposed used Wink) hundreds of times.
Still, there are always risks as for any firmware and if you want to feel more secure, just make sure you have a setup working with Rockchip Flasher, just in case, so you can flash back your stock firmware or try another one.
ultradiv
2012/07/24 - 10:40
Thanks for the encouragement Smile
One question : if I put my 10 G2 into recovery mode (with the paper clip and +vol control) and I can't flash it, will it revert back out of recovery mode with no changes? If so how do I get it out of recovery mode?
Cheers for your excellent help
64 Guest(s)
Devices in use: Desktop (52), Phone (11), Tablet (1)
jacksonrid
