AppsLib & Hublife HD errors.. How to fix please?
Related Tags
tabletlayman
2012/06/18 - 06:51
When I turned on my Arnova 10 G2, two errors pop up:
"The application AppsLib (process com.appslib.vending) has stopped unexpectedly.  Please try again."
"The application Hublife HD (process com.hubkapHD) has stopped unexpectedly.  Please try again."
Has anyone come across a problem similar to this please?  If so, how did you fix it?
Any help would be much appreciated.  Thank you.
2012/06/18 - 08:41
I've never seen such errors. Does it happen everytime the tablet starts ?
Can you try to uninstall (Settings / Applications / Manage applications / ... find each application ... then uninstall button)
and reinstall them ?
Appslib can be downloaded from: http://appslib.com/download/index.html
tabletlayman
2012/06/18 - 21:51
Ooh thanks!  The errors have now both been resolved!  Thank you!
Thank you so much for your help!
sslope99
2012/10/12 - 17:20
I have the arnova 8 g2 and this did not work, says it on a few apps and at start up, but can't seem to reset it, anyway I can do a factory reset, tried the reset button but no joy there, tried a few button combinations to so if there is a defo way of doing it, please help, so annoying :-)
121 Guest(s)
Devices in use: Desktop (112), Phone (9)
spiik
nikitamaan
VMILCINOV
