Wireless keeps disconnecting saying "disabled"
brittone05
2012/02/09 - 19:01
I have just bought a pre-owed 10G2.
When I connect to my internet ( secure wireless home network ), it connect briefly and then says "disbled" and turns off.
Can anyone help?  Spent wasted money ringing their tech support to be told they couldn't help.
Don't want hubby to go and throw a strop with the lad in question who sold me it lol
Any help please?  Have downloaded the latest firmware from their website but no joy at all 🙁 xx
Thanks Received: 3171
2012/02/09 - 19:05
Can you see the connection go to the stage of writing "Connected" ? How long does it stay before it disconnects ?
Have you tried another WIFI access point ?
brittone05
2012/02/09 - 19:16
It gets connected for maybe 10 seconds and then rescns the wireless on the tablet and says "disabled"
Am just about to go over to a friends to try and connect there - back in 10 with results x
brittone05
2012/02/09 - 19:33
Bloomin thing won't turn on now 🙁  I reset it and it now won't come on 🙁
brittone05
2012/02/09 - 22:45
It still won't turn baack on 🙁  the charge light is on green - I tried pressing power button for 10 seconds see if anything happens and the only thing that does is the light turns red and goes green again soon as I let it go 🙁
2012/02/09 - 22:47
Give it a little more charge, then try putting a paperclip in the reset pinhole for a few seconds.
Let us know how it goes.
If it doesn't work, it may require some flashing using Rockchip tools http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
brittone05
2012/02/10 - 08:26
Thanks min I shall give that a try once kids go off to school x
brittone05
2012/02/10 - 08:49
The flashing thing won['t work 🙁  It doesn't even regiter being plugged into laptop and when I try to flash it says "load firmware failed"  It doesn't show any irmware files in the driver folder either 🙁 x
arapp710
2012/06/26 - 16:20
Hi, I am having the same problem as brittone05. My 10 G2 was working fine, then out of no where last night it just stopped connecting to my home network. It keeps connecting quickly and then telling me that it is disabled.  I have not tried to use another connection at this point.  I have reset my tablet though and this did not change the problem.
If someone could respond with an answer for my I sure would appreciate it!
2012/06/26 - 16:24
Maybe it's worth trying to flash again your firmware.
get the firmware from here and flash it following Arnova procedure  or even better, if it works for you thru Rockchip flashing tool.
arapp710
2012/06/26 - 18:14
I appreciate your suggestions.  I have never been able to get my tablet to connect to my pc(Win. Vista). It just wont even read that the device is plugged in. I read thru all of the forums on here, but have been unsuccessful in getting my pc to read it. The tablet recognizes that it is connected to the pc, my pc just doesn't recognize the tablet.  So I have been unable to use this method for anything.  If you could give me some pointers on this topic I'd appreciate it.
2012/06/26 - 18:18
Your computer should mount your tablet thru USB without any problem.  Are you properly allowing the USB mount on the tablet after connecting it to the PC ?
arapp710
2012/06/27 - 02:54
Yeah, I am. I've read a lot of the posts on here about how to turn on the usb debugging. I've done that and still nothing.
85 Guest(s)
Devices in use: Desktop (72), Phone (13)
swan12
heftpflaster
