the battery lighter and the internal storage
amrsadi
Forum Posts: 19
2012/02/22 - 22:11
hi ..
you know , the battery lighter  gives a green color when the charging ends , but with my tablet it's  turn to green even if the charging is still in process alongside with this the charging take along time to be ended more  than before ( when i unplug the charger then insert it again , the lighter gives a red color , but again and again it turns to be green ) ..
another  issue i want to ask about : although i have a 40 m space in my internal storage  it shows me a message sometimes that i don't have a sufficient storage to download a  4 m app from the store !!
disgraceUK
Forum Posts: 15
2012/02/25 - 13:54
I've not encountered either problem.
Perhaps try running the battery completely flat then recharging to 100% and repeat.
Also try closing running apps when trying to install new, might help?
daft
Forum Posts: 64
2012/02/26 - 00:43
dont worry about it... these things are approximate.
Unplug when green unless percent is quite low.
Dont cram the space because the system needs scratch space
amrsadi
Forum Posts: 19
2012/02/28 - 17:27
now the problem is bigger !! ..
the battery life is very short , i cant use the tablet without plugging it to the charger , if i unplug it it will turn off directly , beside this although i connect it all the day with the electricity it will not be fully charged at all ..
i expected  that maybe  a software cause this problem , so i uninstalled the latest software since the problem appeared . but no results !!
what to do ?
Thanks Received: 3171
2012/02/28 - 17:33
Are you using the charger from the default charger that came with your tablet ?
disgraceUK
Forum Posts: 15
2012/03/01 - 18:49
Maybe contact the place purchased from to arrange a repair? Could be a duff battery
amrsadi
Forum Posts: 19
2012/03/02 - 17:43
i sent the tablet to the manufacture , they said that the charger base is loose !  .
i left the tablet there , they will fixed it within 15 days !!
thanks for your effort ,
90 Guest(s)
Devices in use: Desktop (77), Phone (13)
swan12
heftpflaster
