Quick question about setup b4 doing jerrys market fix??
sadsack
Forum Posts: 37
2012/04/01 - 19:38
Hi all,
This may seem like a double post, but I did leave a message for Jerry but he must be quite busy as I have'nt seen him about for a while,   So I thought I would take a chance and repost my question here.
I have been following Jerrys guide and both of his videos, but before jumping in, I just wanted to know (apart from the obvious downloads required that Jerrys linked to) is there anything else required that needs to be installed onto a stock 10g2 8gb that's only had the stock firmware updated on it.
What I mean is does it need anything like arctools to be installed or anything else?? before doing Jerrys market fix?
Thanks chaps for any replies
all the best
sadsack
eagleian
Forum Posts: 18
2012/04/01 - 20:46
Hi sadsack.
No you don't need arctools. Just install the files in the order shown in the video.
It worked well for me as i am unrooted too.
If you get limited apps or unable to connect message just follow Gerry's instructions and all should be ok.
Good luck.
Ian
sadsack
Forum Posts: 37
2012/04/01 - 22:28
Thanks Ian for the Confirmation and reply,
I'll post back and let you know how it went.
all the best
sadsack
sadsack
Forum Posts: 37
2012/04/09 - 21:54
Hi Ian,
Just got round to doing the Market install.
Followed jerrys video, I set up a different gmail account only for the 10g2 on my p.c. before doing the install.
followed the video but unusually I didn't get the error "cant establish a reliable data connection to the server" all it said was something like "syncing your phone" to be honest i can't remember exactly but it was supposed to have shown some kind of syncing icon at the top, but all i had was a small red triangle (a bit like a warning sign).
So i just click finished, went into gmail app, and signed in, then (this is where i thought it was going to go to cock, I went straight ahead and ran "Market",   and it worked, no cleaning of "google framework, or gmail".
I am a total noob at using a tablet and i wondered if you could possible answer a question for me, how do i close the market.  (please don't laugh,).... Is it something to do with "Settings" the icon that looks like a safe,  then applications, then "running services"  i can see settings running, along with hublife HD, google services framework, gmail, and android keyboard.
Or is it something much more simpler than what i am doing.
I didn't want to cock up my market account, i wondered if there was a way of logging out of the market app.
Really appreciate some help
all the best
sadsack
eagleian
Forum Posts: 18
2012/04/09 - 23:10
Hi sadsack
 glad you managed to get the market workng.
I'm not to sure what you mean when you say you canot close the market.
If you mean to to come out of it. You just keep pushing the back arrow until it closes.
Ian
Thanks Received: 264
2012/04/09 - 23:24
you can close the apps that are working by going to settings/manage applications/runing aplications and click on stop on each app.
Or you can use different task killers but is not advised to do that.
sadsack
Forum Posts: 37
2012/04/10 - 01:13
Thanks for the replies chaps....
Yes, you both got what it was I was trying to do, I think I'll go with globula_neagra's answer, but I do appreciate your input Ian.
cheers lads and all the best..
sadsack
p.s.
Sorry about the 1 star..... that's the second time I've done that and the forum won't let me add any more, it was supposed to have been 5, sorry mate. It had nothing to do with your reply, just my stupidity.
90 Guest(s)
Devices in use: Desktop (77), Phone (13)
swan12
heftpflaster
