problem with v1.2 finless
snakekiller
Forum Posts: 25
2012/01/30 - 10:12
When i play some games on 1.2 like trial xtreme 2 then i only seen the wheels of the bike.
With v1.1 don't the bike is full.
Is this something with opengl.
With nfs hot pursuit i don't see my car it white.
With v1.1 it's ok
Verry strange.
Is v1.2 final already so yes where can i downloaded perhaps i maybe i have the beta.
Thanks Received: 3171
2012/01/30 - 10:18
Apart from the data partition size space increase and Arctools support, I am not sure what are the changes in 1.2 custom firmware. Finless should be able to give more details.
Latest custom firmware from finless should be 1.3, not sure if it's officialy released yet.
finless
Stanton, Ca
Forum Posts: 604
2012/01/30 - 20:53
The only difference between 1.1 and 1.2 is the added links to support Arctools.  I am also writing an ID to the IMEI file which has caused most testers to not be able to get the Market working.  I had to remove that in my 1.3 firmware as it did more harm than good.  It seemed that even after my add in init.rc to write to the IMEI it would get written too again later and cause worse problems.
I will post links to my 1.3 version once I chat with admin about it.
Bob
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/30 - 20:58
I tried the bike game this morning on Bobs 1.3 firmware and
It worked fine, did not try the racing game as it was
A paid game.
Jake608
2012/01/31 - 08:15
i am still on 1.1 when will 1,3 be ready and what changes? is there some way to clear the cache without having to do it manually, i keep getting the error message not enough storage and i have to clear them manually, i also get kicked off of the browser, thanks
snakekiller
Forum Posts: 25
2012/01/31 - 16:55
Thx finless
For the pm to your link for v1.3
Everything works fine now even the market.
For the market i did factory reset after flashing and than loggin was ok.
paulpebbles
2012/02/04 - 20:07
hi could i try 1.3 also.
I was wondering has anyone had camera issues with alternate firmwares?
91 Guest(s)
Devices in use: Desktop (78), Phone (13)
swan12
heftpflaster
