Plug in to PC
drchips42
Forum Posts: 38
2012/01/18 - 16:20
I plug in my arnove 10g2 to my win 7 ( 64bit) and it says unknown device.
Had a look on manual and it says "
USB Host port: to connect a keyboard, a mouse or a mass storage
USB device.
Go on the Home screen, tap on the Menu icon , then select Settings/USB Mode select. If the Host
Mode is off, tap on the Host Mode line to turn it on. Important: turn off the Host Mode after use."
As ever that menu option is not there , I have anycut , but cant find the option to change host mode.. any ideas?
HTC Desire CM7.1, Arnova 10G2 ( stock rom ) All Google products fully working!!
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/18 - 16:44
Go into settings/applications/development and turn on USB debugging
This should work. And as far as I know it needs to be connected to a USB 2 port
As it won't recognize it in a USB 3 port
drchips42
Forum Posts: 38
2012/01/20 - 10:45
Yup at home it's not working :
In work Win 7 32bit
At home Win 7 64bit
Think thats  the problem , tried to install abridge etc... did nto work , as it was 32 bit.. 🙁
I have Win XP 32bit VM , so will try that tonight
drchips42
Forum Posts: 38
2012/01/25 - 16:44
The answer , i've worked for 19 years in IT in support , servers , comms etc..
it was the cable
gerry
Forum Posts: 71
2012/01/25 - 18:14
it was the cable
Laugh Cable  how did you come to that conclusion ?
drchips42
Forum Posts: 38
2012/01/26 - 14:58
The end ( adaptor ) fell off .
So now I have a micro usb cable with out the " micro " bit.
The I'll open the adaptor and see if its worth fixing 🙁
88 Guest(s)
Devices in use: Desktop (79), Phone (9)
swan12
heftpflaster
