Philly Tablet upgrade
Gamer819
2012/02/28 - 21:06
mam0856 said
"I thought I did. Can you give me the procedures you used to do your install.I have the download he is talking about earlier in this post but nothing was said about Arc tools. Any and all information would be great"
Before trying the arctools mentioned, you can go to settings\Applications\Mng Applications\All\ select Market then clear data and reboot? I read this in a different group and for some reason worked for me. Have you downloaded and installed the latest arctools from the site?
F.Y.I. I have recently flashed to the new finless custom firmware and couldn't be happier with my philly. It is a different tablet all together. I lost my philly apps but I didn't really want them to begin with.
AN10G2 Finless Custom ROM
mam0856
2012/02/28 - 21:20
Thanks again,  but this stuff is driving me crazy. I have no idea on the procedure on using arc tools to install it. If possible can you tell me exactly how you did it, and what software you used and where you got it.
As far as the firmware thing. If you would not mind can you tell me the same information. How good does that firmware upgrade work.
Currently Online: djamel73
113 Guest(s)
Devices in use: Desktop (101), Phone (12), Tablet (1)
heftpflaster
rk.13
