Philly Tablet upgrade
mam0856
2012/02/21 - 23:38
What are the ramifications of using the upgrade for the Arnova 10 gs on a Philly tablet unit. I'd like to get Android market working on mine
alex
Forum Posts: 252
2012/02/22 - 00:03
Hi unfortunatley the roms built for the 10g2 dont work on the phily yltablet however you can instlall market by following a guide by gerry on how to install market 3.1.3 without root
mam0856
2012/02/22 - 00:08
ok, new here  where do I find that
alex
Forum Posts: 252
2012/02/22 - 15:33
mam0856
2012/02/23 - 14:00
Hi
I tried those 2 downloads, when I clcik on them they take me to a site which says its looking for something, neither one of them work?
Any Help
alex
Forum Posts: 252
2012/02/23 - 15:09
Atthe top right it says skip add try that then pres download
mam0856
2012/02/23 - 15:39
Im confused,   Do I use both those downloads?
alex
Forum Posts: 252
2012/02/23 - 19:30
yes if you open the second link first you will understand the edit at the top
HaroldG
Greater Philadelphia, PA, USA
Forum Posts: 115
2012/02/23 - 19:53
Kasty works fine on the Philly Newspaper tablet.  There are other custom ROMs available for it that also run fine on it not available on this site.  The key thing you have to remember to do is copy your 3 Philadelphia Newspaper apps from the \system\data directory *before* you flash a new firmware or you will lose them.
There is also a way available here to JUST load the Android market and other Gapps without otherwise changing your firmware available here.
mam0856
2012/02/24 - 13:38
Alex,  thanks for your help, but a few questions.
1) I have a google account but not a gmail email,  Do I need a gmail account .
2) Im confused by which download to use first.  Can you please elaborate. I assume I use the one d/l then replace one file with the other in the other d/l.
Thanks for your patience
alex
Forum Posts: 252
2012/02/24 - 18:59
1 yes you need a g mail account log into your google account on google then press mail
2 download the 2nd link first and yes what u asume is correct replace the vending in the second likn with the one in the first, i am in the process of making a blog post and will upload them conbined to avoid confusulion it should be up in a day or two
alex
Forum Posts: 252
2012/02/24 - 19:43
done blog post should be up asoon as admin gives the go ahead and i have changed the forum post so only 1download now
mam0856
2012/02/27 - 17:40
Did as you said. Was able to logon to Gmail, However when I clciked on market I got the following error
" sorry, the application market(process com.android.vending) has stopped unexpectedly. Please try again. I tried several times ,   I get same message.
Gamer819
2012/02/28 - 20:02
I'm new here but I have the Philly tablet and I used the Arctools to install the market and it worked fine for me. Did you follow the instructions on clearing the cache then rebooting?
AN10G2 Finless Custom ROM
mam0856
2012/02/28 - 20:41
I thought I did. Can you give me the procedures you used to do your install.I have the download he is talking about earlier in this post but nothing was said about Arc tools. Any and all information would be great
Currently Online: sevg1, br1anelsnow
90 Guest(s)
Devices in use: Desktop (82), Phone (10)
br1anelsnow
sevg1
osasochi
diefactor
Alorgi
Art787
