Philadelphia Inquirer
paul
Forum Posts: 18
2012/02/15 - 18:03
Hi all, what is the Philadelphia Inquirer versionConfused of the 10G2 tablet, and can I update my standard version with the Philadelphia Inquirer firmware update?, just I thought would askWink , thank you,
Paul.
Thanks Received: 3171
2012/02/15 - 18:06
You will find some info here: http://www.arctablet.com/blog/featured/arnova-10-g2-tablet-bundle-philly-com/
Flashing a non Philly tablet with Philly's firmware won't work.
HaroldG
Greater Philadelphia, PA, USA
Forum Posts: 115
2012/02/15 - 22:04
While you shouldn't use the Philadelphia Newspapers' firmware on a non-PNI tablet, you can install the apps, on stock non-PNI firmware, or Kasty, or any other custom firmware for the Arnova 10 G2.
paul
Forum Posts: 18
2012/02/16 - 22:47
thank you for your help,
paul
psm9
2012/02/17 - 02:47
Any idea why it wouldn't work?  I assume the Philly table is a standard 10 G2 with special firmware.
Has anybody tried flashing a new-PNI tablet with the Philly firmware?
Also, Paul.... if you have the regular 10 G2, you can download the Press Reader app from the Amazon App Store.  If you have a digital subscription to the Inquirer, you can use that app to read it.  It's essentially the same as one of the apps in the Philly Firmware
91 Guest(s)
Devices in use: Desktop (82), Phone (9)
swan12
heftpflaster
