No keyboard with Hotmail
alpha
2012/09/13 - 21:03
Hi
I have a problem as I'm stuck with Hotmail as my main mail account for over 15 years now so I cant/wont change it.
The problem I have is the 10 G2 can open and receive Hotmail but I can't send one, I can enter the email address but as soon as I try tap into the message window a brown boarder encloses the frame, as with the other text input areas, but the keyboard does not pop up or appear so I can't type a message to the recipient.
I have tried different settings but cannot find a solution myself.
I apologise if this has be covered before but I have searched for over a week on the internet trying to find a solution but to no avail.
I hope someone here can point me in the right direction.
Cheers
Thanks Received: 3171
2012/09/13 - 21:45
I suppose you are using hotmail on the web ? Have you tried with another browser such as Dolphin or Opera, may they handle text input/javascript a little different.
If you are not using it already, it's probably good to try Hotmail application on Google Play Store, you'll need a custom firmware to properly have access to Google Play.
alpha
2012/09/14 - 15:39
Thx for the fast reply.
I want to keep it as "stock" as possible as I have too much tech stuff to "fiddle with" to get to work.
It seems these days nothing works "out of the box" ah well........
But...
I have found the default mail client seems to be working
but has no folders creation for different incoming mail organization.
I looked for a firmware/rom update but found nothing from Arnova except the release version.
Is there a "safe" update ?
Many thanks
111 Guest(s)
Devices in use: Desktop (95), Phone (16)
swan12
heftpflaster
