Newbie to the 10G2
masarada
Forum Posts: 18
2012/01/17 - 23:21
Hi all
very new to the arnova 10G2 and here 😉
-How can I rename the application shortcuts on the arnova ?
- why dont the downloaded applications go for storage on the NAND flash , and why only to the internal RAM. any way I can influence this route(i.e. aps go to the NAND flash) ?
Thx. in advance
Regards
simondo
Forum Posts: 78
2012/01/18 - 00:02
1. You cant rename apps and i dont see why you'd want to.
2. Do you mean when an app is installed
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/18 - 00:12
If You Install Go Launcher(Recommend V2.70 for this tablet) than you can rename application shortcuts
simply by pressing the shortcut and hold it, a pop up menu appears with option to rename and even replace the icon.
simondo
Forum Posts: 78
2012/01/18 - 00:23
Ive never had any problems with the latest golauncher
gerry
Forum Posts: 71
2012/01/18 - 01:02
i agree go launcher 2.70 for this tablet too
cirrus
Forum Posts: 37
2012/01/18 - 10:53
 updated to 2.7.6 yesterday and no probs 🙂
damo
Forum Posts: 243
2012/01/18 - 11:09
Just updated to latest version and it seems that they have solved the bugs present in previous versions.
Thanks cirrus
masarada
Forum Posts: 18
2012/01/18 - 15:26
Guyz...Thx. for the info. but I am a wee bit lost here and also being the fact that this is my first tabletSurprised
the only update I know of and did carry out yesterday was via:
http://arnovatech.com/support/updates.html?country=cz&lang=en&p=2
I would not know what and where is the ' 2.7.6' coming from and the how to behind it . any advices here ?Laugh
-as to why I would rename some shortcuts[ @ times there are duplicate shortcuts but with diff. functionalities .e.g. Office suite pro (default) and the Office suite pro 5( free aps)..so just to differentiate ]
- yes, on 'internal storage' i see av. space= 122 MB , while my NAND flash =  2.82 Gig free...ummm any other way I should interpret this ?
gerry
Forum Posts: 71
2012/01/18 - 15:43
Hay Mas
2.7.6 is the version of go launcher application in the android market alot of people speak in versions which is a bit confusing for a new user ,
as for storage i don't think there is a way of saving apps to nand or increasing space from one to the other
Gerry
masarada
Forum Posts: 18
2012/01/18 - 19:41
on a side quest, i did a search on go launcher in the marketplace, and got:
-neonlight theme go launcher
-angrybirds theme go launcher
-planktonic girls theme go launcher
etc etc..
what is the exact search command here ?(exact name for the software )
tia
gerry
Forum Posts: 71
2012/01/18 - 19:48
etc etc..
tia
hey mas
you need to look for
GO Launcher EX
simondo
Forum Posts: 78
2012/01/18 - 19:53
Google golauncher and its the first link.
105 Guest(s)
Devices in use: Desktop (93), Phone (12)
heftpflaster
rk.13
