Newbie help
bsirrell
2013/02/15 - 00:21
I just bought an Arnova 10 G2 4gb
model number AN10G2
Android Version 2.3.1
kernel 2.6.32.27
Firstly when i connect via usb it comes up as a disk drive but when i click on it it says "please insert disk in to drive" Running windows 7 on pc Can anyone help wiith this.
Also would it ok to update the firmware using "arctools 0.76" and "custom firmware 1.12EZ" without any problems?
Also as this device was an ex demo model, i would quite like to restore it to factory condition/settings and do a clean boot.  How can i do this?
Thanks Received: 268
2013/02/15 - 00:48
For restore
Settings/Privacy Settings/Factory data reset, this is from my Arnova 7c G2, but it should be similar on yours.
If you want to acces the internal storage of the tablet you will have to drag the notification bar to the bottom of the screan, select usb connected/ turn on usb storage
It should be ok to flash the firmware via Arctools, if you have any problems, you can always use the manual flashing method with rockchip tools.
bsirrell
2013/02/15 - 13:34
ta
58 Guest(s)
Devices in use: Desktop (56), Phone (2)
jacksonrid
