New to Arnova 10 G2, problems already writing emails.
smitaly69
2012/01/21 - 19:58
Hi ive just bought an arnova 10 G2,has been ok for a couple of weeks i havent used it much,but picked it up today and it seems very slow,in fact when i use the internet the sites load very slowly,ive tried writing emails today but after putting in the email address and then touching the screen  no keyboard pops up so i cant write the message,any clues please? Can i just reset the unit?? Thanks smitaly.
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/21 - 21:07
Firstly do a factory reset from within the tablet settings, to see if this improves things.
If this does not work I would suggest installing the app called Appbackup and restore and backing up the apps you want to keep, as long as you have a memory card it will save the back-ups there.
https://market.android.com/details?id=mobi.infolife.appbackup&feature=search_result#?t=W251bGwsMSwxLDEsIm1vYmkuaW5mb2xpZmUuYXBwYmFja3VwIl0.
Go to Arnova website http://arnovatech.com/support/updates.html?country=gb&lang=en&p=2
and re-install your firmware. Than you will have it back to how it was , re download the backup app above and re-install your apps.
86 Guest(s)
Devices in use: Desktop (77), Phone (9)
swan12
heftpflaster
