New Arnova 10 G2 custom firmware posted (htcmania)
damo
Kingston upon hull, UK
Forum Posts: 243
2011/12/19 - 09:22
Can you confirm if you need to change the file name of the downloaded image file to Img for the g2 to load the firmware?
Is this firmware based on the original rom and has anyone using it
noticed any glitches.
Thanks Received: 3171
2011/12/19 - 09:26
On most Rockchip tablets, the firmware should be named update.img and should be placed at the root of the tablet (top level directory from the Files application on the tablet or root directory from the USB connection)
I haven't checked this firmware yet, can't say how stable it is.
rouge1
Forum Posts: 28
2011/12/19 - 15:05
It’s based on the latest official rom, only Gapps and Market has been added. Very stable, no problems so far.
mausas
2011/12/19 - 16:53
i installed it also, works great, of course best part of it is  - more avalaible space.
daft
Forum Posts: 64
2011/12/19 - 20:14
Does titanium backup work in the restore mode? There were reports of another semi-rooted approach not being able to do this.
Does google market make any more apps available than the "google market lite" you get from the stock non rooted approach? I don't mind the cruder interface of gmarket lite, in fact sort of prefer it.
Does this approach use arctools or does the market just appear? thanks
Harry Ola
2011/12/20 - 10:01
Been following the various discussions here, but not tried any of them until now. Installed this latest firmware and got market up and running without any problems on my 10 G2 4Gb. Installed a shedload of games for my girls to play on Christmas day.
Thanks to all here and at htcmania for your continued efforts. Cool
finless
Stanton, Ca
Forum Posts: 604
2011/12/20 - 10:38
Daft, it does work some what.  I used it to backup my stuff before really getting into trying to hack the fw.  When I went to restore some things did not restore properly like Go Launcher, etc.  However even though this firmware is not fully rooted, knowing what I know now, I do not believe that is what is not allowing titanium backup to work.  /system is ro only so any app you install should be able to be backed up since it was impossible for the app at install time to write to /system.  So maybe titanium backup may need to be updated to support RK29.  Just a guess on my part.
Bob
dbinq
2011/12/21 - 00:01
Anyone seen new Tablet being released soon with Honeycomb http://t.co/zBZxWZPn
blaze187
2011/12/21 - 16:43
i was a bit worried about bricking a brand new tablet by messing with the root etc.ive been using bazzaar android instead it seems loads better than the applib thing, loads more games etc.i have never used android market before.does it have loads more stuff than bazzaar or is it about the same? seems like the safer way to do it.
daft
Forum Posts: 64
2011/12/21 - 18:31
Google market is the ultimate android market with infinitely better quality and number than any other one. If you are concerned about custom firmwares, there is no need for it in order to get google market. There is a topic on that here (something like nonrooted...). Or you can peek at another forum with summarized setup tips http://forum.archosfans.com/viewtopic.php?f=87&t=60005
dwl99
Forum Posts: 29
2011/12/22 - 07:49
I suppose this ROM has no Calendar or Contacts just like the other ROMs?
damo
Forum Posts: 243
2011/12/22 - 15:34
rouge1 said
There is a second custom firmware posted at htcmania with root, market, google apps and 210MB free app space. I just installed it on my 10 G2. Working fine so far.
Here is the link:[Image Can Not Be Found]
http://www.megaupload.com/?d=BAW9EYIG
Maybe a daft question but is this firmware fine for the 8GB version of the Arnova 10G2 ? UK ModelEmbarassed
phoenix1234
2011/12/22 - 21:51
i have just installed this version of FW (read the post about the newer better version but i'll stick to this for now IF i can get just get a little info about the market)
when i open the market up n then open say the games, there is only 1 or 2 gaes showin in each of the categories... is this normal? if not then how do i see the full list of dlc? i am using arnova 10 g2 UK if UK does make a difference.
damo
Forum Posts: 243
2011/12/23 - 10:45
No that is not right, I installed it last night and got full market.
When you first started the market did you log in to your Google account or create an Account?
phoenix1234
2011/12/23 - 12:47
i had to make a new account as my existing google account wouldnt log me in
Currently Online: swan12
92 Guest(s)
Devices in use: Desktop (83), Phone (9), Tablet (1)
swan12
heftpflaster
