Navbar blocking top part of apps
ravingkamikaze2
2011/12/11 - 18:02
Evening
Just trying to set up one of these tablets ready for xmas and have noticed that the top navbar appears to block the top part of apps - main one I am worried about is the Kindle app as it will be used mainly as an ebook reader.
any way I can get the top navbar to hide??
damo
Kingston upon hull, UK
Forum Posts: 243
2011/12/11 - 20:21
You can install a different launcher that the standard android one.
I use Launcherpro because it is a lot faster and smoother than the standard scrolling etc on this device. The programs below you can find on the Android market or Appslib.
Install LAUNCHERPRO
Than install HOME SWITCHER for froyo (dont worry it works for gingerbread).
Start the homeswitcher app and at the bottom click clear default and than click launch on Launcherpro a bit further up the screen. You should get a pop up screen stating COMPLETE USING ACTION, make sure that the use by default is ticked at the bottom and than select Launcher pro. Than you can change the setting to suit your needs, including the option to hide the top taskbar. There are other launchers that have this setting but I find this one the fastest as some of the others on the market are a bit laggy.
[Image Can Not Be Found]
KC87-mufc
2011/12/29 - 19:08
This doesn't work for me on my Arnova 10 G2...
Am I missing something? Does it work for anyone else?
86 Guest(s)
Devices in use: Desktop (73), Phone (13)
swan12
heftpflaster
