LolloBean 1.0 - Jelly bean 4.1.1
yojone
Forum Posts: 26
2013/05/26 - 10:30
if you please, would need help
thanks ...
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/05/26 - 12:14
I stay work on it......
At this moment i am very busy on my work.
Please wait!
Cheers
The following users say thank you to lolloarnova for this useful post:
yojone
adas4190
2013/05/26 - 16:17
Can You just say how to fix this one file please. Just one file :) Build.prop I meant. Thanks :)
dcm
2013/05/26 - 17:58
To fix the build.prop file issue, you need to reflash the tablet then to replace the build.prop use adb because it's easier to change the file permissions. You need to enable USB debugging on settings and then on a command line on the same directory where you have the build.prop file run:
adb shell mount -o rw,remount /system
adb push build.prop /system/
adb shell chmod 644 /system/build.prop
Reboot the tablet.
adas4190
2013/05/26 - 18:31
Sorry for n00b question, but should I do it on tablet or pc?
dcm
2013/05/26 - 18:58
You have to enable usb debugging on the tabled on Settings
The rest is done on the pc but you need to install android sdk to have adb, you need to search this on google.
adas4190
2013/05/26 - 19:24
Should I replace file first? Before running that command? Thank you for Ypur patience :)
dcm
2013/05/26 - 20:34
The commands that I've posted will replace the file and set the correct permissions. You just need to install android sdk.
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/05/27 - 08:41
Use Root Explore, before view build.prop original permission, after apply to build.prop fix, then reboot!
It's easy and work well.....
Bye.
adas4190
2013/05/27 - 17:04
Got it! I already love this rom. It has huge potential! speech recon. Works quite good, chrome,and many more! I love it! Can't wait for final one tho ! :)
yojone
Forum Posts: 26
2013/05/28 - 08:19
good, I can not would be grateful if someone could upload the file
thanks
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/05/28 - 08:22
thanks
File need to you?
yojone
Forum Posts: 26
2013/05/28 - 08:42
 build.prop
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/05/28 - 11:09
yojone said
 build.prop
You find it on FIX Pack...... link: https://www.box.com/s/x97vjwcqps25dptdxsos
Download it, unpack, see original permission from you build.prop, copy it on system, after
apply permission like original, after reboot!
Use built-in app Root-Explore to copy and set permission.
Bye.
yojone
yojone
Forum Posts: 26
2013/05/29 - 22:10
thank you very much friend lolloarnova, changed the permissions and running .....
97 Guest(s)
Devices in use: Desktop (93), Phone (4)
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
mantonero
