LolloBean 1.0 - Jelly bean 4.1.1
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/05/17 - 12:03
                                                           LolloBean 1.0
                                                         Jelly Bean 4.1.1
                                                    For Arnova 10 G2 ONLY
A premise: A big thank you for the rom base Morka!
               A big thank you for the Kernel Arctablet!
Screenshot:
a3yge7y3.jpgImage Enlarger
u2yzuryj.jpgImage Enlarger
ChangeLog 1.0
-Mounting NTFS USB memory
-Full-Play Store
-Launcher optimized
-Video call
-Button-ScreenShot
-Swap Partition 512mega
What Works:
-WIFI
-Camera
-Thethering WIFI (if 3g work)
-Skype video call
-Sensors
-Video Player with Popup!
Does not Work:
-Bluetooth
-3G to be verified
INSTALLATION:
INTRODUCTION: If you install this rom with his Loader, there may be a problem of NOT DOWNGRADE, I'm doing a variety of evidence doing a restore from the recovery I found myself with brickato tab, so I say THAT I DO NOT TAKE NO RESPONSIBILITY 'for any damage to your tablet.
To install unpack the archive, run RK29Update, leave the Loader is not selected, do EraseIDB, then Run!
Recovery will be installed with the original version, if you want I have also attached the CWM Recovery Touch, I have not more mass but if you want .....
If it does not go to fruition the flash remake all over again, but this time select the Loader v2.28 (see INTRODUCTION).
After downloading the package of FIX (copy on your external SD-Card before), here are the files for the rotation sensor, the file Vold.fstab and build.prop.
The file "sensors.goldfish.so" and "sensors.rk29board.so" should be placed in the folder "system / lib / hw /" just copied the tablet reboots itself, you will now have the rotation working.
Vold.fstab Then copy the file to the folder "system / etc" and reboot. You will now have the internal memory functioning, and the door usb standard usb working for usb memory etc ...
Take the build.prop file and copy (use Solid Explorer or Root Explore) it to the folder "system" and reboot.
Last step to get the full Play Store, after much tribulation are managed with an app, it's called Market Helper, here the link: http://codekiem.com/2013/02/13/market-helper/, download and install it, then choose the model you want, i put Tablet Nexus 7, goes to great!
The file is in the archive recovery touch FIX, if you want to try do it at your own risk!
Advice that, you can just install the Busybox updated, improves some programs, such as Titanium, Teamviewer ....
Sorry for the excitement! It 's the first time I'm on the other side of the fence!
Link FIX: https://www.box.com/s/x97vjwcqps25dptdxsos
Link ROM: http://www.arctablet.com/users/forum/LolloBean1.0.rar
Cheers!!!!!!!!!
The following users say thank you to lolloarnova for this useful post:
globula_neagra, xenafan, freiserk, yojone, p2pjack
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
russel_mufc
2013/05/17 - 21:47
Cool
yojone
Forum Posts: 26
2013/05/18 - 11:47
Very good ROM, installed without problems but installing latest build.prop file and reboot the screen stays on and does not boot android, that serves this file necessary???
thank you very much and very good job only lacks I run BT and artwork will
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/05/18 - 14:31
yojone said Very good ROM, installed without problems but installing latest build.prop file and reboot the screen stays on and does not boot android, that serves this file necessary???
Edit build.prop and copy line different from fix !
I stay work to new version with fix inside!
Bye.
Blackyx007
Forum Posts: 19
2013/05/20 - 17:21
Nice to see more development for our tablet will try this rom as soon as I'm back home Cool
dcm
2013/05/20 - 23:08
That happens when the the build.prop file has the wrong permissions. The tablet won't boot if the file permissions are other that 644.
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/05/21 - 17:37
yojone said Very good ROM, installed without problems but installing latest build.prop file and reboot the screen stays on and does not boot android, that serves this file necessary??? thank you very much and very good job only lacks I run BT and artwork will
Thank's i forget it!
yojone
Forum Posts: 26
2013/05/23 - 22:20
yojone
Forum Posts: 26
2013/05/23 - 22:24
good, what is the solution, can operate without this file????
and have noticed that going slower will hardly think this file is missing???
thanks
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/05/24 - 16:35
thanks
Copy Build.prop then set permission 644 (like original) after reboot!
If you can replace it!
Bye.
yojone
Forum Posts: 26
2013/05/25 - 11:45
good, as you change permissions
thanks
adas4190
2013/05/25 - 23:26
Copied Build.prop,I make shure it has 644 permission and still no success after reboot. Help
Thanks Received: 264
2013/05/25 - 23:38
thanks
Bye.
Do you need help to build an update image that includes the files from the FIX ?
adas4190
2013/05/25 - 23:39
yes please :)
57 Guest(s)
