Installing Android Market on your Arnova 10 G2 in less than 10 mins with the EZ custom firmware
maribo
91
2012/08/10 - 09:42
I have a arnova 10 G2 4gb
Installed the Kasty firmware. Problem is getting a message like "SDcard full flag ..." .
After erase nand flash etc the message did not disappear.
After installing a 32GB SDHC SD card nothing changed.
How can i get rid off that message of a "full SD card" ?
I hope anybody can give me a solution.
bob
maribo
92
2012/08/14 - 13:25
I tried to install the newest version.
Downloading: Kasty-ez-arn10g2-23-12.zip
Unzipped: update.img
Via USB to root of the arnove.
restart
Result after formatting etc. just the screen with text ARNOVA. System did not act anymore during a long time.
What can be wrong?
I also tried to start the flashtool with the same file, but the same result
Any suggestion is welcome
bluebaz
93
2012/08/20 - 16:37
Hi there, I need help.
I got an almost new 10G2 running on gingerbread and decided to install the EZ firmware in order to access the market.
after downloading Arctools, selecting firmware, selecting the correct one, checking the disclaimer box and hitting download I get this:
"error 95 - firmware file copy failed. archive file cannot be accessed. please check that your device is not mounted on a usb"
my device is not plugged into anything so I'm at a loss.
I must admit I'm not hugely tech savvy (average 40yr old trial and error type learner) but I cant see that I've done anything other than follow the simple instructions to this point. Any help would be greatly appreciated. (UK based so may be time lag in replies)
p.s while blundering about randomly pressing things to 'investigate' the issue, I went into the internal memory and noticed a Kasty-ez zip file. pressing it gave me options to 'complete action with'. I chose 'using package installer' and I got: 'parse error. there is a problem parsing the packaging'. I have no idea if this is significant as i dont know what a parse is Confused
excuse my ignorance, cheers.
Confused
joekonesko
94
2012/09/28 - 01:13
Having lot of problems updating flash firmware.Wont read then keeps freezing the touch screen plus since got tab been having lots of manufactor issues any help plz
paul2415
95
2012/11/17 - 13:10
I have the ez software  installed on my arnova 10 g2 4gb,i have managed to get it to run on arctools for google play store but it does not seem to be stable,i have to use the recovery to get it to start sometimes,so i want to flash the tablet and install the standard arnova software,can this be done via the tablet alone ?if so how do i do this ?thanks.
delcedric
96
2013/02/05 - 15:39
Hi guys!
I've installed the Firmware and Arctools 0.76 but when I try to download Default Apps & Market, Error 25 appears: Copy File Failed. No access to the archive file.
Anybody has the issue?
Thanks a lot!
aussiebird73
97
2013/04/26 - 22:07
Hi all
I have tried to download this but each time I get this message:
"Error 95: Firmware file copy failed - Archive file cannot be accessed, please check that your device is not mounted on USB" and it is not mounted on anything... any advice?
171 Guest(s)
Devices in use: Desktop (159), Phone (12)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
