Installing Android Market on your Arnova 10 G2 in less than 10 mins with the EZ custom firmware
crypton8755
46
2012/03/29 - 21:24
Hi' I'm new to the arnova 10g2 it's got android version 2.3.1  I have apps from apps lib on the sd card and on the tablet, do I need to delete them before trying to install android market ? Confused
crypton8755
47
2012/03/30 - 11:37
I installed new firmware for android market last night and it worked perfect, shut the tablet down and this morning it's dead, cant even reset it. Anyone got any ideas.
Thanks Received: 3171
48
2012/03/30 - 12:46
You can use Rockchip flasher tool to recovery a "bricked" device.
fire194
49
2012/03/31 - 12:56
All of this is for the Arnova 10G2 4gb tablets....So I used the EZ install with version kasty-ez_arn10g2-23-11 2 weeks ago and had absolutely no issues at all. Play Store worked great with all the apps. Today I am fixing my mothers tablet and I use version kasty-ez_arn10g2-23-111 and it initially bricked my tablet. Needless to say after many forum views and a few hours later, I was able to unbrick it and install kasty-ez_arn10g2-23-111. At first Play Store would only show 3-4 apps. I tried all the Market fix procedures and nothing worked. So I decided to go back to my original tablet that is working and I took the version from 2 weeks ago and substituted it on the tablet, used arctools to reset market and then one reset later...All apps are in the Play Store.
So to whomever changed the versions thinking it would help, Please Please Please change it back to kasty-ez_arn10g2-23-11 so others don't run into the same trouble I did. I really appreciate the firmware and all the solutions found on this forum. You all rock!
50
2012/03/31 - 12:58
Thanks for your feedback. We are in the process of updating our Kasty firmware to fix the different recent problems encountered with Google Play Store (former Android Market)
We'll post an announce when our firmware updates are ready.
crypton8755
51
2012/03/31 - 23:43
Down loaded the flasher tool but now my computer wont recognise my arnova 10g2 tablet so I cant use it at all to do any repair. anyone got any ideas on how to get the computer to recognise the tablet. The reset option does nothing.                                     (windows vista home premium 64 bit)
Thanks Received: 264
52
2012/04/01 - 00:39
maybe you should instal first the drivers, that should be the first step
cerbius
53
2012/04/01 - 10:13
Hi, I've just completed stage one and seem to have lost the ability to connect to the internet. It scans for available wifi attempts to authenticate with the network before disabling it.
help please
thanks
andy
54
2012/04/02 - 10:40
help please
thanks
andy
Have you tried other WIFI access point that you can connect to ?
Can you try flashing again the firmware ?
petergettins
55
2012/04/13 - 17:25
Just to say I loaded this & it all works perfectly, thanks
sozmic
56
2012/04/18 - 20:24
Recently did this on my 4gb and it worked perfectly thank you
craigb
57
2012/04/20 - 23:55
Hi everyone
I recently bought two Arnova 10 G2  4GB Tablets  for my son and step daughter and have been very impressed with the two devices. My only disappointment was when i realized that there was no Android Market support but then i found out about Arctools and the custom firmware EZ1.11 and installed as instructed. Everything went well and i've installed apps from Google Play without any problems but i've just been made aware of problems with audio on both Tablets.
The 1st Tablet has no sound except when headphones are connected. The 2nd Tablet has sound but when the same headphones are connected the audio still comes from the tablet speaker no audio comes from the headphones.
Anybody else having this problem and is there a fix?
Many thanks
Grinder
Murphy, NC
58
2012/05/07 - 20:16
I just uploaded the EZ custom firmware on my tablet ... the only issue im having is the browser just shuts down while im surfing the web now... anyone else have this issue? If so, what's a fix for it??
OK gang... Ima gear head here... not a techy... I tried the Rockchip... couldnt make it work... I tried rooting the tablet with the kasty firmware, but for some reason cant get it to work on my Win 7 laptop... I am having a heck of a time with this tablet... I even tried the upload.img to restore and cant get that to work either... but, I do have the android market and that is working fine... I just cant browse the web, cause just as it is loading up a site, the browser closes... please, can anyone help a fella out? Thanks for your time...
_/Grinder_/
stupiduser
59
2012/05/10 - 08:26
WARNING WARNING....
Of course it is my fault and I was stupid doing this, but I only tried the flash because I did see that there was an unbrick tool. In my case and several other cases the unbrick doesn't work. See the forum notes.
By the way: The flash went fine, and everything seemed to work. Only after a shutdown, the tablet got bricked.
Dik
60
2012/05/10 - 08:31
Your device is probably not bricked, you should be able to recover it and flash a new firmware, please check Rockchip flashing tool.
180 Guest(s)
Devices in use: Desktop (165), Phone (14), Tablet (1)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
