Installing Android Market on your Arnova 10 G2 in less than 10 mins with the EZ custom firmware
Andrew
31
2012/03/09 - 10:02
Hi, a few people have asked if this will work with the Arnova 10G2 4mb but no one has answered this yet. I would like to know the same thing. Thanks
baalmoloch
32
2012/03/09 - 11:46
It works absolutely fine on a 4GB.
dominicene
33
2012/03/09 - 18:17
Hello I'm new to Android,
Is it confirmed that this EZ custom firmware will not work on the Arnova 10 G2 - Philly Tablet.
I noticed that there is a firmware update for the Philly Tablet on the Arnova website.
Does anybody know if it has the Andriod Market  on with the update
I would actually would like to know please what is the safest option to add Market to my table. I don't want to brick my tablet. I'm
kinda scared trying this but if it will work on my device then i will give it a try. How can i ensure that I don't brick it ?
Thank you so much
dominicene
34
2012/03/10 - 10:09
I'm sorry i'm a newbie ... is the arnova 10g2 4mb the same as the philly tablet ... i'm weary about installing if the post says it only works on the 8gb model ... please advise
pedja
35
2012/03/11 - 20:08
I installed EZ1.1 without problems. In fact, there is one small problem, I cannot connect to it through USB. Namely, Vista asks me for the driver for Arnova 10G2 and I don't have it. With the old firmware, it didn't ask anything. Do you have any advice about this? Thanks.
dominicene
36
2012/03/11 - 20:09
Do not try the E-Z custom firmware Yell ... it will brick your device Yell... its not worth the trouble ... try the safer option from here ...
http://www.arctablet.com/blog/forum/arnova-10-g2-general/video-google-apps-and-android-market-install-guide/ .. I'm pretty sure if you happen to have any issues ... Gerry will be helpful. Smile
The people on this post were not very through or helpful. I'm not sure if my question was repetitive or I was being ignored but I found this particular post to be disorganized, misleading and confusing. Confused
I found the un-bricking tablet using rock-chip post and how to install android without rooting post by Gerry was exceptional
I got android market installed. Got my tablet back its all good. Cool E-Z custom firmware option is trash ... need more work
neeson
37
2012/03/12 - 20:41
Hi i am new to android so apologies if I am missing something very simple... I have a new 10 g2 4GB I installed EZ custom firmware and everything seemed fine - Android market was on my tablet, entered my google details noticed there were apps missing.
When I went to settings I could not find Market to clear cache - now I dont seem to have the Market on my tablet anymore??tried to download using arc tools but am getting error message 20 and 28 when trying to install apps.
Can someone advise me please hoping i am missing something simpleLaugh
Thanks Received: 3171
38
2012/03/12 - 20:46
Can you check if you have a Play Store icon in your Apps list.
There are chances that your Android Market has been updated to the latest software, which is now called Google Play Store.
neeson
39
2012/03/12 - 20:50
hi yeah I just noticed that I had Google play store and it has / is replacing the android market!? Sorry as I say I am new to Android!
40
2012/03/12 - 20:52
No worries Wink
pedja
41
2012/03/12 - 21:07
I was just wondering if anybody else experienced this. When connecting my Arnova 10G2 after installing EZ1.1, USB connection doesn't work. Vista asks me to insert disc that came with Arnova 10G2. It didn't ask before instaling EZ1.1 firmware. I'm not aware of any USB drivers for Arnova 10G2, so now I cannot use USB cable to connect Arnova with PC.
dnstark
42
2012/03/16 - 17:05
Hi
I've just done this fix for my Arnova 10G2 4MB, and everything seemed to work fine.
However, if I ever actually use the Android Market to download an app, the download works great, but Market then immediately disappears again - and I'm back to square 1.
What have I done wrong? Why won't this new firmware "stick"?
43
2012/03/16 - 17:07
Your "Android Market" may have been upgraded to "Play Store", which is the new product name of this Google app. Please check for Play Store in your application list.
Skywriting
44
2012/03/20 - 20:18
Firstly, thanks for doing all of this!
I've followed all of the steps successfully on my Arnova 10 G2, including the fix for missing apps in the Market Place. However, no app in the Market can be installed -- every single one displays the message "Your device isn't compatible with this item".
Also, as an aside, a search for YouTube (as shown in the video) does not return any results for the official app.
Help!
45
2012/03/20 - 20:19
You can either try the Market fix as show as the end of the video, or flash again (we have just released a new 1.11 update with latest Google Play Store/Android Market).
201 Guest(s)
Devices in use: Desktop (189), Phone (12)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
