I can not connect with my google account
Ciccio Pasticcio
2011/11/08 - 12:01
I followed your guide to install google market, it is extraordinary!
You are great!
Should I ask for your help:
I can not connect with my google account, my tablet is not communicating with the google's server .
How can I solve this problem?
Thanks Received: 3171
2011/11/08 - 12:28
Ciccio Pasticcio said:
You are great!
It can be many things, including a temporary outage on Google side.
Try to connect from another WIFI access point.
Just wait a bit and try to connect again later.
(I have moved your question to a separate topic)
Ciccio Pasticcio
2011/11/08 - 12:41
Thank you,
I tried to connect to another access point but continues to report:
"Can not Establish a reliable data connection to server"
... What can I do?
thommo
2012/01/02 - 12:00
go into settings and app management and find gmail app select it and then clear data then reboot and log into gmail first then you should sync and be able to log into the market aswell.
88 Guest(s)
Devices in use: Desktop (76), Phone (12)
swan12
heftpflaster
