how to connect external hard drive, does it have to be powered? please help
oliman
2012/01/11 - 04:25
Cool
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/11 - 08:28
Yes it would have to be powered
cirrus
Forum Posts: 37
2012/01/22 - 15:37
a 3.5 inch external drive needs power, but a 2.5 inch "laptop" HDD does not reqire external power.
finless
Stanton, Ca
Forum Posts: 604
2012/01/22 - 16:33
I think it is going to depend on the drive and it's power requirements.  My 2.5 drive requires power on my Arnova 10 G2.
Bob
cirrus
Forum Posts: 37
2012/01/22 - 16:52
most probably  be down to drives RPM ect , i have 2 and both get power from usb bus only.
apparently they are notebook drives which require less power.  thanks for the info i was under the impression all 2.5 was powered by usb bus. seems it is not the case.
 regards.
finless
Stanton, Ca
Forum Posts: 604
2012/01/22 - 17:16
My 2.5 is from a dead laptop but it is a older model.  I put it in a USB case I bought made for 2.5 drives. The case has an optional 5V power jack. It will power by USB on a PC, etc no problem but the Arnova will not power it.  Once I plugged in the 5V wall wrt to it, the Arnova saw it fine after that. So again my point is I think it depends on how power hungry the drive is on USB power alone.
Bob
damo
Forum Posts: 243
2012/01/22 - 19:31
My two external sata hard drives wont work with the tablet, just get notification
Come up safe to remove usb
One is a WD 1tb external powered, the other is a Sumvision cyclone pocket, un powered
Tried everythingFrown
gerry
Forum Posts: 71
2012/01/22 - 20:20
copyed from the arnova site
USB devices
What USB devices work on the tablet?
Quite a lot of simple USB devices work on Android Tablets via the USB host. Common layout USB keyboards work, most USB mice, USB flash drives even some USB hard drives (as long as they are self powered). For a USB device to work in Android the drivers need to be there, google have added drivers for many devices but not for all. The best way to know if your USB device is compatible with Android is to contact the USB device’s manufacturer. Or simply plug it in and see.
damo
Forum Posts: 243
2012/01/22 - 21:07
Surely mass storage is standard regardless of make...
The USB mass storage device class, otherwise known as USB MSC or UMS, is a protocol that allows a Universal Serial Bus (USB) device to become accessible to a host computing device, to enable file transfers between the two. To the host device, the USB device appears similar to an external hard drive, enabling drag-and-drop file transfers.
The USB mass storage device class comprises a set of computing communications protocols defined by the USB Implementers Forum that run on the Universal Serial Bus. The standard provides an interface to a variety of storage devices.
An USB flash drive like this one will typically implement the USB mass storage device class.
Some of the devices that are connected to computers via this standard include:
Devices which support this standard are referred to as MSC (Mass Storage Class) devices. While MSC is the official abbreviation, UMS(Universal Mass Storage) has become common in online jargon.
Cut from Wikipedia
cirrus
Forum Posts: 37
2012/01/22 - 21:31
seems bob was correct, some usb devices can draw power from USB bus whilst others need a lil external boost.
102 Guest(s)
Devices in use: Desktop (93), Phone (9)
swan12
heftpflaster
