HDMI on Arnova 10 G2
2012/01/09 - 08:47
I don't think this cable model will work, because it's made for an USB MHL enabled port, which shouldn't be the case on the Arnova.
For other options, the USB HDMI adapter would need drivers, which may not be available for Android. I don't see any adapter compatible for that purpose currently.
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/09 - 09:34
It is a bit of a useless adaptor really as USB does not have the same bandwidth
As hdmi. So for things like watching hd content from USB
To hdmi on a tv just would not work. USB is just to slow for this.
And like admin said it would be drivers etc.
We never did find out if the arnova 10g2
Does support the soldering option ?
s1t
2012/01/09 - 16:58
Ok thanks ! I was really hoping that this method can work...
register
Forum Posts: 84
2012/01/23 - 19:17
damo
Forum Posts: 243
2012/01/23 - 21:11
register said
it seems in china the arnova 10 has the hdmi port as standard
http://www.beareyes.com.cn/2/lib/201109/09/397/4.jpgImage Enlarger
http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.beareyes.com.cn%2F2%2Flib%2F201109%2F09%2F20110909397.htm
also the camera is said to be 720p hd camera
The HDMI port is blanked out like on the normal Arnova 10G2, strange as it does mention it, more likely to be a typo or wrong info, and as far as I know the normal 10G2 has 720p anyway
register
Forum Posts: 84
2012/01/24 - 00:43
youre right - on the picture the hdmi is capped...
as for the camera - it doesnt seem to be an hd camera judging from what it displays
take a picture and the best settings and youd see its 640x480
thats not 720p
thats vga
damo
Forum Posts: 243
2012/01/24 - 01:13
thats not 720p
thats vga
I think they mean 720p video, but the camera quality is not the best I agree
sark4u
2012/03/10 - 22:31
Hi
I have replaced the power jack of my Arnova 10 g2 and after   that my touch screen stops working. Can any body please tell me which connectors I have to check to make sure the are properly connected.
jamierk
2013/03/07 - 15:07
Can anyone tell me if the arnova 10b g3 supports MHL. I know the best way for video output is hdmi, but not an option here. I want to know if the micro usb can be used as a video output before i waste money on the cable.
2013/03/10 - 18:43
Don't waste money on the cable, the Arnova 10b G3 USB port doesn't support MHL.
KBL
Forum Posts: 12
2013/03/17 - 21:48
Can you tell me how you got the cover off? I have a GBook ANGB that needs a Micro USB fix.
Does it just clip together and a little prising would separate the front and back gaining access to the motherboard?
142 Guest(s)
Devices in use: Desktop (134), Phone (8)
