custom firmware Issue
jimbo
2012/03/26 - 20:35
Just bought G2 and downloaded custom firmware but always get error messages 28 cannot create temporary directory and 20 file copy failed when downloading app for android (play) market - App appears but keeps telling me device not compatible when trying to download standard apps such as facebook and ebay. have restored and retired number of times but no joy - can anyone help
Thanks Received: 3171
2012/03/26 - 20:39
It seems our EZ firmware (the one that probably have downloaded) currently has some problem with Google Play. We are working on fixing the problem.
There are other alternative firmware that you can use:
http://www.arctablet.com/blog/forum/arnova-g2-general-discussions/morkamod-android-3-honeycomb-look-on-arnova-7g2-8g2-9g2-and-10g2-support-topic/
http://www.arctablet.com/blog/forum/arnova-10-g2-general/arnova-10-g2-improved-firmware-ext4-android-market-full-root-increased-app-storage-space/
jimbo
2012/03/28 - 11:00
thanks for this will try later Smile
jimbo
2012/03/28 - 15:47
restored to normal firmware following Arnova installation image file which automaticaaly installed as per instruction I then copied arn10g2-23-20 in its entirety as a winrar zip file to root level but device not recognising and have not had message to install new firmware - admit I'm a novice but struggling - have also reconnected to make sure file copied across - should i be installing Arctools as well ?? Sorry to be a pain but really want Android market FrownFrownFrownFrownFrown
2012/03/28 - 16:07
Using the following method (see also the video) is probably the easiest method to install Android Market/Google Play Store.
http://www.arctablet.com/blog/featured/installing-android-market-arnova-10-g2-ez-custom-firmware/
jimbo
2012/03/28 - 16:12
have tried this method but this is what led to the problems I had at the start of the forum and led to the reply "It seems our EZ firmware (the one that probably have downloaded) currently has some problem with Google Play. We are working on fixing the problem."
2012/03/28 - 16:22
Can you please try again, we have made some updates on the Google Play libraries.
jimbo
2012/03/28 - 18:13
everything downloaded great so far but can't, according to google play, establish  a reliable connection to the server> double checked wifi connection and have successfully used browser !!!!CryEmbarassedCry
jimbo
2012/03/29 - 21:48
reloaded and confirm all now workingKiss
99 Guest(s)
Devices in use: Desktop (84), Phone (15)
heftpflaster
rk.13
