Battery life
bert
2012/01/23 - 00:01
I've had my 10g2 for about a week, but still the battery monitor estimates are still very inaccurate. I get to about 50% on the percentage left and it will shutdown, after plugging in and restarting it then reads only 5-10% left and requires a 3-4 hour recharge at least, i've tried a few monitor apps and widgets and get the same, i've not found one yet which reads the mv remaining either accurately?
Im aware these things take a few charges to settle in but i've not seen any improvement yet. Is this normal for this device?
gerry
Forum Posts: 71
2012/01/23 - 00:14
Hey Bert
you could try Battery Indicator Pro , you should get min 10 hour out of your g2 ,try that app if your still not satisfied take it back to the shop for a replacement
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/23 - 08:34
I had the same problem before took it back for a replacement. Looks like it is faulty
onericardo
Forum Posts: 13
2012/01/23 - 14:56
My tablet requires 8h or more to recharge. Is this normal ?
gerry
Forum Posts: 71
2012/01/23 - 16:02
onericardo said yeh
Yeh mine takes 6-8 hours from flat dead but you can charge it when ever you like but for more efficiency its best the battery is flat 0%
damo
Forum Posts: 243
2012/01/23 - 16:09
gerry said
onericardo said yeh
With regards to the battery type that the Arnova 10g2 has here is some tips for usage. The Arnova 10g2 has the 3rd type in the table Lithium!
When I first got mine I was a bit puzzled at to how to charge etc so this should help people
Frequently
asked question
Lead acid
(Sealed, flooded)
Nickel-based
(NiCd and NiMH)
ARNOVA 10G2
Lithium-ion
(Li-ion, polymer)
How should I prepare a new battery?
Battery comes fully charged. Apply topping charge
Charge 14–16h. Priming may be needed
Apply a topping before use. No priming needed
Can I damage
a battery with incorrect use?
Yes, do not store partially charged, keep fully charged
Battery is robust and the performance will improve with use
Keep some charge. Low charge can turn off protection circuit
Do I need to apply a full charge?
Yes, partial charge causes sulfation,
Partial charge is fine
Partial charge better than a full charge
Can I disrupt a charge cycle?
Yes, partial charge causes no harm
Interruptions can cause heat buildup
Partial charge
causes no harm
Should I use up
all battery energy before charging?
No, deep discharge wears battery down. Charge more often
Apply scheduled discharges only to prevent memory
Deep discharge wears the battery down
Do I have to worry about “memory”?
No, there is no memory
Discharge NiCd every 1–3 months
No memory
How do I calibrate a “smart” battery?
Not applicable
Apply discharge/charge when the fuel gauge gets inaccurate. Repeat every 1–3 months
Can I charge with the device on?
Some UPS systems simultaneous charge and deliver current.
It's best to turn the device off during charge; parasitic load can alter full-charge detection and overcharge battery or cause mini-cycles
Must I remove the battery when full?
Depends on charger; needs correct float V
Remove after a few days in charger
Not necessary; charger turns off
How do I store
my battery?
Keep cells above 2.10V, charge
every 6 months
Store in cool place;
a total discharge causes no harm
Store in cool place partially charged, do not fully drain
Is the battery allowed to heat up during charge?
Battery may get lukewarm towards the end of charge
Battery gets warm but must cool down on ready
How do I charge when cold?
Slow charge (0.1): 0–45°C  (32–113°F)
Fast charge (0.5–1C): 5–45°C (41–113°F)
Do not charge
below freezing
Can I charge at hot temperatures?
Above 25°C, lower threshold by 3mV/°C
Battery will not fully charge when hot
Do not charge
above 50°C (122°F)
What should I know about chargers?
Charger should float at 2.25–2.30V/cell when ready
Battery should not get too hot; should include temp sensor
Battery must stay cool; no trickle charge when ready
Please Read with regards to letting battery go flat before charging as this may wear battery down
finless
Stanton, Ca
Forum Posts: 604
2012/01/23 - 19:29
FYI it takes a lot longer to charge if the unit is on.  Also I have seen cases were the LED never goes green if the unit is on yet it fully charged long ago.  So don;t judge charge based ont he LED alone.
Bob
register
Forum Posts: 84
2012/01/24 - 00:12
indeed these issues are quite annoying
the device will power on by itself when the charder is plugged in
and if you dont inted to use it it just stays on with the calibration screen on it
and it takes forever to charge
so every time you have to wait for it to power on and then switch it off
bert
2012/01/24 - 00:47
Thanks for all the replies. I'll see if it improves. I think i might have a faulty unit though.
I got again to 38% today and it powered off, on restart it was at 7%, after which ive given it a full charge again. Im noticing aswell that it appears to increase if i put it in standby aswell by 10% roughly and then rapidly discharges back to where i left it before after use for a few minutes.
I'll give a few more cycles, otherwise back to the shop for a replacement.
damo
Forum Posts: 243
2012/01/24 - 01:11
I would not bother just take it back your symptom is the same as mine, you unit should not be like that, but it is important you fully charge you new one before you even attempt to use it, it does switch on when you plug in your power lead, just switch it back off as soon as it boots!
drchips42
Forum Posts: 38
2012/01/26 - 15:03
Use a 3rd party like circle battery to show you what power is left .
This seams to show the true value in terms of charge , mine has been working all night before on 52%... the tablet says it's 20%...
HTC Desire CM7.1, Arnova 10G2 ( stock rom ) All Google products fully working!!
107 Guest(s)
Devices in use: Desktop (92), Phone (15)
swan12
heftpflaster
