2012/09/27
LolloBean The FINAL!
JellyBean 4.2.2 AOSP
Arnova 10 G2
Based on rom OMA, a BIG THANK!
INSTALLATION:
Flash the ROM, and do get into CWM Wipe Cache, then Flash Zip and select the file
CrewRKTablets_AOSP_4.2.2_Format_NAND_Fix, once done Reboot your tablet!
I have attached a tweak to give a sprint to the system! is called CrossBreeder_7.2.13 and should be flashed from recovery, then reboot and load an app Terminal and issue this command:
su-c "/system/etc/CrossBreeder/zzCrossBreeder FORCE" and sending, it should be done only once! I assure you it is worth it!
BUG **: GMAIL app does not correctly display the email, I'm working on ....
LINK: https://www.wuala.com/LolloMix/LolloBean%20The%20Final/
Donation PAYPAL:https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=KS454U7VZQQCL
Cheers!!!
The following users say thank you to lolloarnova for this useful post:
kairi223
2012/09/27
kikias58 said
I use rockchips for flash room I does not how understand(include) to install(settle)?
Open Rkandroidtool, select all (no backup) after EraseId, after Run then read Instruction!
I wait your opinion, and if you want make a donation!
Cheers!
kairi223
2012/09/27
2012/09/27
kikias58 said
I have erasing IDB failed !!!!
Did you run RKAndroidTool with admin rights?
2012/09/27
2012/05/23
good friend, managed to install all that when I put (su-c "/ system / etc / CrossBreeder / zzCrossBreeder FORCE") in the Terminal application puts me not found.
Also when I go into SETTINGS / DISPLAY / is closed and has been closed sets application settings
ire testing and comment
as always thanks for the good work.
2012/10/12
lolloarnova, thank you very much for your hard work!
But there is little mistake in this command, must be
su -c "/system/etc/CrossBreeder/zzCrossBreeder FORCE"
And I see later:
/system/etc/CrossBreeder/zzCrossBreeder: line 255: can`t create /system/block/mcblk0/bdi/read_ahead_kb: nonexistent directory
/system/etc/CrossBreeder/zzCrossBreeder: line 254: can`t create /system/block/mcblk0/queue/read_ahead_kb: nonexistent directory
ls: /sys/devices/virtual/bdi/179*/read_ahead_kb: No such file or directory
/system/etc/CrossBreeder/zzCrossBreeder: line 256: can`t create /sys/devices/virtual/bdi/179:0/max_ratio: nonexistent directory
It`s OK?
Arnova 10G2 with "GingerComb" Finless 2.2b CWM (Pro ROM) --->>LolloBean 2.0 (Jelly Bean 4.1.1)
2012/09/27
And I see later:
It`s OK?
About CrossBreeder i post original forum link,
Please see this link! http://forum.xda-developers.com/showthread.php?t=2113150
66 Guest(s)
Devices in use: Desktop (59), Phone (7)
