[ ROM ] Arnova 10 G2 improved custom firmware update (full root, increased app storage space) by Finless
Tags: bob
Related Tags This topic is locked
Kahndryl
106
2011/12/26 - 23:49
finless said
For Market login problems, do these steps and it usually solves it.  I have had it happen a few times myself and it does matter which version of Market I installed.
1) Go into manage apps, select all apps (not just downloaded), and find; Google Services Framework.  Click on that and click on the clear data button.
2) No go back and find Gmail if you have it installed.  Go into that and clear data as well.
3) DON'T DO ANYTHING at this point!  Power off completely and power back on.
When you come back up go right to the market and try to logon using your existing account.  It should work.  This procedure has always cleared up the first login issues I have had when first installing the Market.
I have the same problem. But your solution doesn't work. I applicated it three time, and nothing. Have you got an other idea? (I did the installation of market from arctools 0.60 and 0.57 with the three propositions for each)
Thank you for your work! Except the market, the rom works perfectly and the more memory is very nice!
tanktech87
Forum Posts: 21
107
2011/12/26 - 23:54
@ ayrton If you transfer arctools 0.57 to the device from you computer, disconnect safely then go into the files app on your device. go to where you planted the arctools 0.57 file then click and install it. Once uve done that follow bobs instructions stated above 🙂
Ayrton
Forum Posts: 11
108
2011/12/26 - 23:58
Sorted. Thank you gentlemen!
finless
Stanton, Ca
Forum Posts: 604
109
2011/12/27 - 00:00
FYI, settings / manage applications is NOT your apps drawer!
Bob
tanktech87
Forum Posts: 21
110
2011/12/27 - 00:04
yes yes my bad sorry bob. im just going to wait for a solutions and hope it works. thanks for everything dude !
d@d388
111
2011/12/27 - 00:13
hi bob,
sorry if i post again my question but i want know if i can edit the system.img adding in it new apk without problem or did you edit it to do it work
thank you so much
finless
Stanton, Ca
Forum Posts: 604
112
2011/12/27 - 00:15
It should work but if it is all messed up at this point do the following.  This will erase everything on your device!
1) Go into Storage and erase NAND memory
2) Go into Privacy and do a factory reset.
Try again after that.  This erases everything and gets you back to a normal system without 18 version of google installed that maybe conflicting.
Bob
tanktech87
Forum Posts: 21
113
2011/12/27 - 01:49
Ive done the noobiest thing and bricked my machine !!! I tried installing the stock firmware from arctools 0.57 on top of your rooted one !!! how do i surpass this idiotic move? bob, god, anyone?....please help. I just want to go back to stock firmware
finless
Stanton, Ca
Forum Posts: 604
114
2011/12/27 - 01:51
Forget that last post... I just tested.  The Arnova Erase NAND and then restore factory does not erase stuff that got installed in /system.  I guess it doesnt expect stuff to be written there prior to my ROM that allows it.
So to fully erase and get back to a fresh factory setup you have to flash the ROM again with my tools AND IMPORTANT.... Erase IDB.
Also now that I am installing apps and stuff it is clear I need to allocate more space to /system!!!
So I am going to put together a new rom that gives /system about 100megs of free space.  This should take care of any "root" based applications.
Give me a few days as Admin also wants me to add hooks to allow Arctools an easier time at installing and I just need to work with him on that to get it right.  I want to try not tro release a new ROM every few days!
Bob
finless
Stanton, Ca
Forum Posts: 604
115
2011/12/27 - 01:56
Read the notes for my ROM install.  I tell you the links to download the stock firmware and use the RKBatch tool to reflash in recovery mode.  In my readme, I give links here on Arctablet that explains how to do it. Don't panic!  If you were able to flash my ROM you have the drivers installed.  All you need is RKBatch Tool and the stock update.img from Arnova.
Although why you would want to go back to stock is beyond me.  It's not going to solve your Market issues.  My ROM does not change how the Market would work IF you can even get it installed on the stock system.  If you must go back to stock use this proceedure as it worked for me before I rooted the ROM:
/blog/forum/arnova-10-g2/install-android-market-without-root-on-latest-firmware/
Bob
tanktech87
Forum Posts: 21
116
2011/12/27 - 02:33
I never had the market installed on the stock one but appslib. I'm not panicking!! Just frustrated with it. Thing like these i can follow straight away but I must have done something wrong along the way with this one. Cant seem to put my finger on it though. I ad the market on the old cfw and it worked fine but i wanted to be greedy and have more memory. Going to reflash it now with RKBatch tool.
I eventually got a UK 3.4.4 android market on my device but it wasnt showing all te apps and still wouldnt download. Well, here goes.......
tanktech87
Forum Posts: 21
117
2011/12/27 - 02:55
Opened up RKbatch tool pointed to the update.img
clicked upgrade..everything ok
Opened up RK29update, clicked the loader box (ver 2.08) Clicked eraseIDB
Clicked run...everything ok...
Right I have a fresh clean flash on my device.
Do you advise me to install arctools 0.57 then install the 3.4.4 (rooted) package?
Honestly sorry for all the dumb ass questions dude. Wish i could pay you 🙂
finless
Stanton, Ca
Forum Posts: 604
118
2011/12/27 - 03:22
Yes please.... Install Arctools 0.57 and do the rooted 3.4.4 install or Market.
Let me know at that point now that you have a fresh flash how it works.  Admin would probably like to know if his 3.4.4 Market works for UK folks.  THIS IS NOT ROM related but I would like to know and maybe help.
I am here so let me know how that goes.
Bob
tanktech87
Forum Posts: 21
119
2011/12/27 - 03:22
My last post now (its 2am here) im going to bed. Right...Ive installed arctools 0.57 installed the rooted 3.4.4 package...rebooted. I now HAVE a UK android app market....BUT for some reason there isnt many apps on it??? Installed yahoo app to see if it would download and it did. Just a shame about the market not showing all the apps. 1 more thing...my super user icon is now green, it was black before. Dont know if that means anything. Well thanks for everything man. Is there an actual way I could pay you dude...honestly.
If you have an idea why the market is not showing the full apps let me know please man. I'll check back tomorrow
PEACE
finless
Stanton, Ca
Forum Posts: 604
120
2011/12/27 - 03:27
PEACE
The black Super User icon was either my old ROM 1.0 or someone elses ROM.  My verison 1.1 has a green and dark grey icon.  That could have been your issue before... Wrong ROM!  As for all the apps not showing up.  You mean compared to what?
3.4.4 does detect your device and can limit you on apps.  For instance Google Earth says "not for your device".  Yet I have the 6.1 APK from some where I downloaded it on and it install and works.  So please understand how the Market works.  It "may" filter content because of your device compared to say a phone or something.
Good night.... Hope all this was helpful!
Bob
62 Guest(s)
Devices in use: Desktop (55), Phone (7)
