[ ROM ] Arnova 10 G2 improved custom firmware update (full root, increased app storage space) by Finless
Tags: bob
Related Tags This topic is locked
naytf
Forum Posts: 15
316
2012/01/18 - 19:40
How can I without the driver add the market. I crashed reset the whole thing but the market won't load. Maybe we can try to make this easier to install. Its good so far bob. But lets try to fix flash and I think Java is no good on the 10g2. Is there an update can't find one myself.
finless
Stanton, Ca
Forum Posts: 604
317
2012/01/18 - 20:06
For Java and what not get a better browser.  I like Dolphin HD.  As for Flash install 10.3 not 11.x as 11 has problems on this Tab.
Bob
naytf
Forum Posts: 15
318
2012/01/19 - 05:33
I am running dolphin HD and I still have the same probe. And I have flash is 10.3 was 10.2. No different I can see. Its the "toolbar" on the individual page. There supposed to sit still as I scroll , and they move with me. I think its Java that controlled these. I've tried everything I can think of. It has to be a bit deeper.
simondo
Forum Posts: 78
319
2012/01/19 - 06:13
Ive always used 0.60 without problems
naytf
Forum Posts: 15
320
2012/01/19 - 06:29
If you log in to android market via a browser then open a link to the app a few times eventually the android market app will work no matter wht version of arctools you use. I've done it on both now. I reset every thing fallowing the direction in previous posts. Then when it tab loads installed arctools from a SD card. Download, install. Reboot. Open mrket. When it ask you to sign in. Click the alternate. Sign in using browser. It'll then push you back to the app after sign in. Download dolphin HD. If market won't open again, go to market.android.com install an app. No maatter what it is pick one. Click install you should get a choice to open with browser, dolphin, and market. Click market. Oh make sure your signed in to market on the webpge before install. It should start working fine. If not, do it again. Mines a HSN 10g2 with bob-ware.
silversurfers25
321
2012/01/19 - 21:09
Hey Bob,
Not sure if its of any interest but theres a post in XDA about getting Flash 11.1 working on Tabs only compatible with 10.3 using a mixed 11.1 and 10.3 version.
I haven't had a change to install and test it. Maybe at the weekend if I find a spare minute 🙂
http://forum.xda-developers.com/showthread.php?t=1284489
Dave
pope_acute
Belfast
Forum Posts: 21
322
2012/01/20 - 12:13
Help, i refuse to believe my nova won't work, it must be P.I.C.N.I.C.
i made a video of what i'm doing, why can't i get market working? I've tried Installing vending.apk separately, and does put a market app icon in the drawer but it exists to desktop straight away when you try to create/open an account.
any pointers as to what mistakes i'm making?
thanks
sorry for poor filming and editing just to get point across
http://vimeo.com/35366066
Arnova 10 G2 unmodded (yet)
323
2012/01/20 - 12:31
thanks
Thanks for taking the time to make the video...
At first sight, I think the selected package in Arctools is the cause of the problem.
ArcTools 0.57 is not able to process the "root" package install, to use it you'd need version 0.60, that you can get from Appslib or Arctablet.com homepage.
Best option is probably to use Arctools default package, first in the list.
I am not sure if this works with finless's initial custom firmware from this forum topic or if it needs a later one:
http://www.arctablet.com/blog/forum/arnova-10-g2-development-forum/new-arnova-10-g2-fully-rooted-firmware-now-available/#p1126
or even more recent.
Sorry about the difficulties with these programs and version firmware uses, I am working with finless to clean this up and have a single firmware + Arctools release that should work immediately.
Let us know how it goes.
pope_acute
Belfast
Forum Posts: 21
324
2012/01/20 - 13:02
ah ok, i'll try that later, after work, cheers.
the only one i never tried was 0.60, downloaded 0.56,0.57.0.58, from arctablet repository, tried them with no joy, just for "try it" sake. Just following the instructions from the readme.txt file and read on the forum 0.57 was the one to use.
http://www.arctablet.com/blog/forum/arnova-10-g2-firmware/arnova-10-g2-improved-custom-firmware-update/#p1189
cheers for the pointer.. 🙂
drs
325
2012/01/22 - 15:17
Hi
I bought my Arnova 10G2 yesterday.... after few hours, all works fine 🙂
New firmware, arctools 0.57, install market (root) and all is good. Thanks for the great job.
Just a question: with the original firmware, wifi wes good. But with the custom firmware, wifi indicates a 72Mbps connexion...wifi n??
(sorry for my english, but I am a french man 🙂 )
finless
Stanton, Ca
Forum Posts: 604
326
2012/01/22 - 17:06
Pop_acute, well first off you are running my first ROM release.  If you read through the development post my first release had some issues with getting full ROOT access.  I quickly fixed that and released another one.  However back then I was not versioning the ROM so you could not tell which version you have.  By the looks of it you have my very first one which had some permission problems with /system.
So you need to download and use my 1.1 ROM.  On my boot screen you will see the version number on it.
Go to this blog post and scroll down.  Int he firmware download box is the 1.1 version:
http://www.arctablet.com/blog/forum/arnova-10-g2-firmware/arnova-10-g2-improved-custom-firmware-update/page-11/#p3561
File name should be arn10g2-23-1_1.zip
With this ROM do not use Arctools 0.60 as it will fail to download the 3.4.4. Rooted install.  So use 0.57 like you have.  DO EVERYTHING just like you did in your video (3.4.4 Rooted Install) and it will install and put a market app in your app drawer.  This entire problem you are having is again because you did not download my updated ROM per the blog post.
I think this will fix you up.  However after running the market if you get "could not establish a connection" when trying to logon to your google account, this is a common problem people have.  Noting to do with my ROM.  You will need to read some of the posts here about clearing cache, etc to get the market to work if you have this problem.  Some have it and some it works first time..  It's seems to be 50/50.  Good luck.
Bob
pope_acute
Belfast
Forum Posts: 21
327
2012/01/22 - 23:57
haha cheers Bob, that done the trick, helps if i use the correct version.. all good!
thank you for all the help with this..
finless
Stanton, Ca
Forum Posts: 604
328
2012/01/23 - 19:40
Your welcome!
Bob
HaroldG
Greater Philadelphia, PA, USA
Forum Posts: 115
329
2012/01/29 - 00:07
Bob -
Just ran the install on my Philly Newspapers Arnova 10 G2.  I had tried to root on my prior tablet, but something was wrong with the memory and it became bricked.  This is the replacement unit and runs nicely, and now is rooted with all that marvelous space, Titanium backup, and JUST the apps I want on it.
Just curious, is it possible to run Nandroid backups from the recovery?
Thanks again!
330
2012/01/29 - 01:01
Harold, good to see you back with a working tablet Wink
To my knowledge, Arnova G2 devices currently does not have a full featured recovery like Clockwork on Android phones, so there is no possibility of running Nandroid backups.
Currently Online: oblaarggag
52 Guest(s)
Devices in use: Desktop (47), Phone (5), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
