[ ROM ] Arnova 10 G2 improved custom firmware update (full root, increased app storage space) by Finless
Tags: bob
Related Tags This topic is locked
monkfiish
301
2012/01/15 - 09:32
I have the same issue with windows 7 64 bit. Did you locate a driver?
oldduck
Forum Posts: 21
302
2012/01/15 - 15:04
When you browse for the drivers folder, it has 2 sub-folders: 32bit and 64bit, go into the 64-bit folder, and you will see driver for Win7 and Vista.
naytf
Forum Posts: 15
303
2012/01/16 - 02:21
Having issues with flash 10.3 aswell. Or maybe its the browser. I'm put boxes don't let me type if flash is installed. I have the same prob on stock browser ans dolphin HD. On Han firmware stock firmware and bobs all do the same. Can't find any help. Maybe its a firmware issue since they all dirived from the same base with minor mods. Any tips bob. Oh dialog works without flash but can view view without it.
finless
Stanton, Ca
Forum Posts: 604
304
2012/01/16 - 02:35
Sorry I am not fully understanding the problem?  Also where did you get your flash 10.3 version from?  I have heard that the one for the Arnova is different and to not load the 10.3 from appslib.
I would post the 10.3 that came with the Arnova but Adobe may not like me doing that.
Bob
fabio70mi
Milano, Italy
305
2012/01/16 - 10:53
To Finless,
I would like to connect Arnova 10G2 to Internet with USB connected Nokia phone (5800XM).
It's not working out of the box like USB Internet keys.
With Linux it works using cdc_acm driver included in vanilla kernel. I think this module is present also in Android kernel but it's not included in our tablet.
Could be nice to give a try in next ROM you will provide.
thank you
Fabio
Dodger77
Birmingham, UK
306
2012/01/16 - 11:23
Hi Finless,
I've been using your updated firmware since Saturday, all's been fine til yesterday when market 3.4.4 installed using arctools 0.60 stopped working. Tried clearing data etc to no avail so did a full factory reset, managed to get market reloaded and working again but now only have market 1.82 which is giving me prices in dollars. I have been unable to update it using any of the methods on arctools.. Any ideas?
Cheers
Dodge.
damo
Kingston upon hull, UK
Forum Posts: 243
307
2012/01/16 - 15:47
When you installed the firmware you should of used v0.57
Of arctools to install the market. You can try to clear the nand storage
In storage settings followed by factory reset in privacy.
Now use the 0.57 version to install the market. If this does not
Work than you may have to reflash and install market
Dodger77
Birmingham, UK
308
2012/01/16 - 15:54
Cheers,
Where will I get the 0.57 version from? The strange this is that it was working fine up til yesterday..
finless
Stanton, Ca
Forum Posts: 604
309
2012/01/16 - 17:06
Download arctools 0.57 from here:
/blog/wp-content/uploads/2010/12/com.arctablet.arctools057.apk
If using my ROM you MUST reflash to get rid of anything that got installed in /system like other Market installs may have done.  The reseon is the factory reset thing does not expect /system to have been written to so it does not clear that out.  So you must EraseIDB and reflash to get a clean system.
Install Arctools and use the 3.4.4 Rooted intsalll choice.
Bob
Dodger77
Birmingham, UK
310
2012/01/16 - 17:24
Cheers Bob,
I'll redo it later, any idea why it was working then stopped?
finless
Stanton, Ca
Forum Posts: 604
311
2012/01/16 - 17:41
No clue.  I have never seen that before.  Login issues are usually after first install of the market. After you get passed that, it usually works from that point.  Maybe you lost WiFI or something?
Bob
Dodger77
Birmingham, UK
312
2012/01/16 - 18:12
WiFi was on the whole time, I'll reflash later and let you know what happens.
Dodger77
Birmingham, UK
313
2012/01/16 - 21:40
Cheers Bob,
That appears to have done the trick, I'll keep an eye on it over the next few days.
Dodge.
314
2012/01/17 - 08:52
Please ask in our Forum, you'll be better chances to get answers.
http://www.arctablet.com/blog/forum/arnova-10-g2-firmware/
Thank you.
nipper
315
2012/01/17 - 11:59
nwhite89 said
Ok I am just tried again and thought I would write what Steps I have taken
1) Run RKAndriodTool v1.29 (on Stock ROM)
a) Erase IDB again
2) Installed Finless Rooted ROM v1.1
Link Here : /assets/firmware/Arnova10G2/arn10g2-23-1_1.zip
3) Gone through Startup Wizard
4) ERASE NAND and then Privacy Factory Reset
5) Setup Wi-Fi
6) Installed ArcTool v0.57
Link Here : /blog/wp-content/uploads/2010/12/com.arctablet.arctools057.apk
7) Used ArcTools to install "Default Apps & Market 3.4.4 (root Install)
8) Turned off & on
9) Loaded Market app and added account
10) Downloaded my new APPS! 🙂
Just wanted to say thanks to Finless this ROM is awesome 🙂 makes the Device so much faster so not even taking into Account Market its awesome.
Plus thought people may want to use the steps I took above
AND Cool Just adding to everyone's compliments to Finless for such technical acumen (Great work Bob!) and for displaying the right stuff all round. I used the above protocol for ultimate success but it wasn't without its tense moments. It took a couple of attempts to install the drivers on XP; there was an unexpected restore after the NAND and Privacy reset (that was just my naivety I suppose) and afterwards a Wi-Fi conundrum when I couldn't connect; which required me to configure a new password as the old one simply wouldn't work. If I can pass anything on it is this; keep a cool head, be patient and especially start afreshLaugh. Re-flash, new WI-fi password and when the protocol says at 9. "add account" don't try to add your old gmail account like I did! Start afresh. Thanks again to Finless and also many thanks to nwhite89.
Currently Online: oblaarggag
56 Guest(s)
Devices in use: Desktop (53), Phone (3), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
