[ ROM ] Arnova 10 G2 improved custom firmware update (full root, increased app storage space) by Finless
Tags: bob
Related Tags This topic is locked
finless
Stanton, Ca
Forum Posts: 604
2011/12/22 - 21:42
Wow guys I found one of the major reason that /system was RW but some things would not work.
For any of you guys doing this on your own. DO NOT take files created by or touched by Windows.  Wendals tools when they unpack make some files in /system with ownership of user 400 not root!  His tool .lua script does chmod but does not use chown to switch all files to ownership root.
Then if you work on a file and open it in windows even if you do not edit it, the ownership is changed to user 400.
Freakin Windows!  Now I am doing everything in Ubuntu and things are working.
So my mistake folks.  Hey... I am learning here so please forgive.  I will have a new version 1.1 rom today.
Bob
p1ceus
Forum Posts: 38
2011/12/22 - 21:51
No problem man, take your time 🙂
Dayveee
2011/12/22 - 22:49
This is all great with 10 G2! Now, does anyone want to get started on a Gingerbread/ICS port. For I would truely love that. :3
Dayveee
2011/12/22 - 22:57
Honeycomb I mean.
You have permission to slap me silly.
rouge1
Forum Posts: 28
2011/12/22 - 23:28
I was able to fix the permissions by mounting the system.img and “chown –R –h root:root *” and Refash.  Rooted apps are working fine with this.
As for arctools. This is not working.
finless
Stanton, Ca
Forum Posts: 604
2011/12/23 - 00:11
Arctools requires some symbolic links to be made to /system to work.  I have done that and it is working now.
rouge1, yes this is what I did to /system in Ubuntu and then saved the new system.ing which solved ALL the problems.  Freakin WINDBLOWS!  I love it for some things but this kind of stuff requires Linux that doesnt change stuff on you (like ownership) when you don't want it to. Thats what I get for using it to pack and unpack or edit files 🙁
I am almost done with the new rom that will support Arctools.  I am going to leave appslib in for the new people as they need some kind of market to start out with!
Anyway sorry guys for the trouble.... Really...  I should have tested more myself.... Can't thank you all enough for testing and letting me know the issues.
Bob
RavenBrother
2011/12/23 - 00:14
Hi,  Thanks for yourCool hard work.  It is us who can not do what you do that need to thank you Finless.
finless
Stanton, Ca
Forum Posts: 604
2011/12/23 - 01:05
I am uploading to my server now.  Stay tuned.  In about 20 minutes I will update this post with FW version 1.1.
AGAIN... you guys are testing for me even though I have tested everything people posted here that did not work.  It all works now including Arctools, EF file manager, Titanium backup, etc.
Be right back with my link.  I hope the admin is around to update his blog post with my new version as I am worried my server will get hammered until he gets it posted here.
Bob
finless
Stanton, Ca
Forum Posts: 604
2011/12/23 - 01:29
OK.... again sorry all for making you guys BETA testers!  Crap happens 😉
I am pretty sure I got this all fixed now.  Here is what is new:
1) This should be full root this time!  Damn it ticked me off I made those ownership mistakes in the first ROM!  Call me a n00b it's OK 😉  I can take it cause I am!
2) Appslibs comes installed with the ROM.  New people need this at a minimum so I left it in this time.
3) Arctools works!  Get version 0.57 from appslib.  When it runs use install market 3.4.4 (root Install). The rootless install does not work for me.  But root install does with no issues.
4) The boot screen now says version 1.1 so you know you got the right version.  If when you reboot it does not say that, your on the old 1.0 version!  FYI, my original had no version number on it. Now they will always.
5) Nothing else has changed that I am aware of!
I will work on a update.img version but I have to tell you NO ONE has successfuly done that yet that I am aware of including the for T760, Wopad, or Nextbook.  They all require use of RKAndroid flash tool 1.29.  This is because the boot.img for RK29 is different and has a header and footer.  We can recreate the header but not the footer at this time.  The AFPTool requires the footer to make a proper update.img.  So sorry but until I can crack this issues, no update.img 🙁
Here is the link: http://www.helifreakswag.com/arn10g2-23-1_1.zip
Admin please host this as soon as you can as I fear my server will barf if it gets hammered.
Thanks all....
Bob
rouge1
Forum Posts: 28
2011/12/23 - 02:11
Market (root Install) in arctools is not working. the normal Market 3.4.4 version is working.
the rest seems to be working fine.
finless
Stanton, Ca
Forum Posts: 604
2011/12/23 - 02:16
I used Arctools 0.57 and installed 3.4.4 (rooted) and it worked fine for me.  You have to reboot as it says.  I tested this at least 3 times myself from a fresh flash!  Please can you state the steps you used and when it did not work please.  This bothers me as again I tested at least 3 fresh flashes 🙂
Question... Did you EraseIDB before you flashed?  This is important!
Bob
finless
Stanton, Ca
Forum Posts: 604
2011/12/23 - 02:27
FYI I used on the 4 choices in Arctools the bottom choice; "Default apps & Market 3.4.4 (root install).   I did not test anything else other than "Default apps & Market 3.4.4 (rootles install), which did not work for me.  Remember Admin is BETA testing rootless install now so please use the (root install).
Bob
rouge1
Forum Posts: 28
2011/12/23 - 02:31
I did EraseIDB.
Arctools .57 is no longer in appslib, only .58
finless
Stanton, Ca
Forum Posts: 604
2011/12/23 - 02:35
OK I just did a ERASE NAND then followed by a >privacy>factory reset. The system rebooted.
Then I installed Arctools 0.57
Then I ran Arctools and selected; Default apps & Market 3.4.4 (root install)
I downloaded the package using the Arctools download button
I clicked "install" using the arctools install button
I cold rebooted the Arnova e.g. turned it off and back on.
It booted back up and the Market app was in my applications list.
I ran it and logged in.
Everything worked.
Please let me know what did not work for you with arctools as I cannot recreate a failure using the above.
Bob
finless
Stanton, Ca
Forum Posts: 604
2011/12/23 - 02:37
CRAP..... OK let me download Arctools 0.58.  Sheesh... I hope thats not it 🙁
Bob
Currently Online: run2droi
77 Guest(s)
Devices in use: Desktop (53), Phone (25)
roro17920
anbague
run2droi
iceman14
AnyFox
BAMHAB82
