arnova 10 g2 firware
swagger
2011/11/27 - 10:34
Hi guys     ive been trying to update my arnova 10 g2 with the official firware update from arnova and i cant seem to get it to go on my tablet, any advice on what i,m doing wrong.
ive downloaded file and copied and pasted onto root (I drive) and nothing happens,
can anyone help.....what exactly does this firmware put on the tablet ?
cheers   swagger
Thanks Received: 3171
2011/11/27 - 11:05
Are you copying the firmware file (update.img, not the zipfile) at the root of your device ? (when you mount your device on your computer, it's the most upper level directory you can see).
The firmware update can also go to the root of your sdcard, you can copy it using a sdcard reader on a remote computer.
swagger
2011/11/27 - 11:08
Hi i am copying the img file there isnt a zip file with it
2011/11/27 - 11:22
Well make sure you are copying it in the right place.
The firmware update dialog comes when you unmount the USB connection to your remove computer. It also popups (sometimes) right after the Android system boots on the tablet.
85 Guest(s)
Devices in use: Desktop (72), Phone (13)
swan12
heftpflaster
