[ ROM ] Arnova 10 G2 first custom firmware with Android Market and root
nkpchen
76
2011/11/14 - 05:21
anyone can run the link2sd succesfully after applied the custom rom??
If yes, can you teach me how to do it?
kernoman
Forum Posts: 16
77
2011/11/14 - 20:46
I have flashed this firmware today and it all went very smoothly however I can not get the market to work, it keeps asking me to create an account and when I try to connect using my existing account it comes up
'Can't establish a reliable data connection to the server.'
I installed the market using the latest version of arctools and have tried all 3 versions of the markets it has to offer and all do the same thing.  I even tried installing youtube.apk and setting up an account from there but that did not work - the account creation works fine in the youtube app but if I then open up the market and tell it to use that account I keep getting 'server error'....arghh so close!! can anyone help?
elmonica
78
2011/11/15 - 09:06
I restored the Arnova 10 G2 default firmware. I had some issues with Pandora Radio pausing and not re-starting. Plus it bugged me that I used the 250 app allocation so quickly, so I figured why bother.
LaM
79
2011/11/15 - 12:28
Guys...I've installed it and everything's fine! (no philly)
Thou...psx player doesn't work, fpse works but it's painfully slow, some games like trial x doesn't works correctly...
Inotia 3 works, air control lite works but menu is someway splitted (but still playable), gapps fully works, navdroyd works.
PLZ, KEYLOCK NEEDED! I was able to specify unlock pattern (using 3rd party app) but I wasn't able to make it working properly! Any Ideas?
Benchmarking it with antutu vs my hts desire says that hardwarely speaking are pretty the same (10g2 is a little bit more powerfull on 3d hw)
If u tell me how to dev an image I can help maybe!
Thx for Your work btw!!!
kernoman
Forum Posts: 16
80
2011/11/15 - 12:37
Did you not have any issues when creating an account for the market place?
maribo
81
2011/11/15 - 13:35
 Same problem here
maribo
82
2011/11/15 - 13:36
I installed the market using the latest version of arctools and have tried all 3 versions of the markets it has to offer and all do the same thing.  I even tried installing youtube.apk and setting up an account from there but that did not work – the account creation works fine in the youtube app but if I then open up the market and tell it to use that account I keep getting 'server error'….arghh so close!! can anyone help?
 Who could pass this problem?
LaM
83
2011/11/15 - 14:42
No I didn't. I followed the procedure using arctools (thx guys for developing it!) installing all the 3 versions from the oldest to the latest.
kernoman
Forum Posts: 16
84
2011/11/15 - 18:19
I just did all of that and still can not log in to the market, can anyone help this is driving me nuts!!
LaM
85
2011/11/16 - 11:15
Can U reflash the firmware?
odonnell
86
2011/11/16 - 14:15
Do not install flash 11 keep the 10.3 version, your browser will be fine.
kernoman
Forum Posts: 16
87
2011/11/16 - 18:51
LaM said:
Thanks LaM, i reflashed the firmware and that fixed the issue, i noticed a few extra apps that i didnt have when i flashed it last time, no idea why it didnt work for me the first time but its working now [Image Can Not Be Found]
bruce
88
2011/11/17 - 14:01
How stable is the new firmware?
I have just bought a 10 G2 and would like market but can't afford to brick my machine.
damo
Kingston upon hull, UK
Forum Posts: 243
89
2011/11/17 - 15:06
I live in the UK and bought mine from Comet.
You install the custom firmware just the same as you do the Official firmware from Arnova,
Just make sure that you have your device plugged into the power or have a decent amount of battery power. The Firmware only takes about 4 minutes in total to complete so this is just precautionary.
I have had the Custom firmware on the tablet now since it was released and I have had no problems with it. Bearing in mind that this is a first release it seems spot on, but there are people working on the firmware to test it and improve it.
I now have the Official Android market on the device which is much better that the Applib market that is installed with the original firmware. So you can use Google Mail, Maps, YouTube etc.
My advise to you is try it and if you dont like what you see simply put the original firmware back on it it is that simple. My own personal opinion is to gain access to Google programs, services and the Proper Android market is a must and I wont be going back to the original firmware anytime soon.
LaM
90
2011/11/17 - 15:35
kernoman said:
LaM said:
Np buddy, glad it was helpfull! =)
54 Guest(s)
Devices in use: Desktop (51), Phone (3)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
