[ ROM ] Arnova 10 G2 first custom firmware with Android Market and root
damo
Kingston upon hull, UK
Forum Posts: 243
61
2011/11/08 - 12:12
I have used app2sd to move all the programs that I could to my memory card.
I have started using app cache cleaner and this freed up quite a bit as program cache is stored in the internal storage space and not on the sd.
Using android info app from the android market to check what internal storage I had left after doing showed some improvement.
I installed disk usage to show what exactly was using up system internal storage and found that things like live wallpapers, some google apps, and apps that where part of the firmware that could not be moved to sd could be uninstalled so I did that with all the stuff that I didnt need. It seems that some programs store themselves on the system memory and some just install straight onto the sd card. Everthing I install now, the app APPSD informs me if it can be moved to the memory card.
Been quite new to Android seems like it is a bit of a poor state that this is the case, but reading in this forum Cybersoft the creators of the custom firmware has a way round this which will be released soon so that system files can be stored on an sd card to free up memory, unless there is already a way around this.
Some more information regarding this would be very helpful if the site admins can shed some light on this issue and give the newbees some more information would be great [Image Can Not Be Found]
Ruben
62
2011/11/08 - 14:57
It means that your tab is compatible with windows 7, so you can hook it up by usb to tranfer files.......
Ruben
63
2011/11/08 - 14:58
Eeehhmm.....would you be so kind to post a link here when it's ready, cuz my spanish in't that good 😉
I am
64
2011/11/08 - 21:12
Thanks for answer:)
jimmy2b
65
2011/11/08 - 21:35
I have successfully flashed/rooted my Philly 10G2 tablet. Worked completely as described. I will say that I had already flashed a new official image from Arnova effectively erasing the entire Philly newspaper app bundle.
I do however have an issue with the Market app. When launched for the first time it asks to login to (or create) a google account. The app seems to be attempting to place a phone call through a data provider. It tries then reports
'Can't establish a reliable data connection to the server.'
'This could be a temporary problem of your phone may not be provisioned with data services. Call customer care... '
I've seen postings here about the Market working and I have to wonder how? Do I really call cust. care at google?
Andy
66
2011/11/08 - 22:25
Hi
Do you have a wifi connection established? I have used this method and now have working market.
sky
67
2011/11/10 - 14:38
Very Good for Market and Root. Now I can enjoy my arnova 10 G2. Thx!
Jerry
Hong Kong
68
2011/11/10 - 15:03
hi there I'm from Hong Kong and I buy my 10G2 with about US$200 few days ago~
I've just root and flashed the firmware in T-Chinese and it's good ~!!
it runs Market good, nothing bad happen on my 10G2 … at this moment
but it still can't A2SD itself, hope that it can be fix in future ~[Image Can Not Be Found]
but anyway , GOOD JOB ~
looking forward to see the new ICS firmware for 10G2![Image Can Not Be Found]
69
2011/11/10 - 15:13
it runs Market good, nothing bad happen on my 10G2 ... at this moment
but it still can't A2SD itself, hope that you can fix it in future ~[Image Can Not Be Found]
GOOD JOB ~
Thanks for your feedback and good to hear it's working for you.
We are working on increasing the partition for the data storage or having an option such as A2SD to increase the limited storage for applications.
HaroldG
Greater Philadelphia, PA, USA
Forum Posts: 115
70
2011/11/10 - 16:07
Not sure whether this unit suffers from the issue some other Android handsets have.  There, the \data\data partition is strictly limited to 150mb, so as soon as you hit that wall, you get "low memory messages."  There is an exploit to relocate that to an ext4 partition (perhaps from the 4megabyte internal drive), but not sure whether this unit would support such an approach, and of course, I suspect the \data\data partition is smaller given the smaller RAM footprint.
Jay
71
2011/11/11 - 05:28
I flashed this rom and everything works good except browser keeps shutting down by itself, have tried different browsers, they all shut down unexpectedly.
nkpchen
72
2011/11/11 - 09:24
Dear Jerry,
May I know how can you find the rooted firmware with traditional chiness support?
KP
Jerry
Hong Kong
73
2011/11/11 - 16:13
just simply to root this firmware when your 10G2 is original have T-Chinese
whatever the Arnova official firmware or this one
not a matter ~~[Image Can Not Be Found]
Jerry
Hong Kong
74
2011/11/11 - 16:14
nkpchen said:
Dear Jerry,
KP
minerva1961
75
2011/11/12 - 18:18
Worked for me on both my kids tablets...  Many thanks!!
64 Guest(s)
2 Guest(s)
Devices in use: Desktop (58), Phone (5), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
