[ ROM ] Arnova 10 G2 first custom firmware with Android Market and root
Qnti
46
2011/11/05 - 07:41
No. First I just installed whit this tut. and it was good, but i was needed to set another google account so I just reset the device, to clear the things. Than there was no market. I try to do the steps as like before, but now doesn't worked in the same way.
Qnti
47
2011/11/05 - 08:16
No. First I just installed whit this tut. and it was good, but i was needed to set another google account so I just reset the device, to clear the things. Than there was no market. I try to do the steps as like before, but now doesn’t worked in the same way.
jtarsilla
48
2011/11/05 - 10:45
admin said:
The error 28 while installing the Market was a small issue in current ArcTools update (0.54).
It has been fixed in latest release 0.55, please update ArcTools, either by:
- switching to a different tab while in the application (the update should be offered)
- downloading the updated APK from Arctablet blog (see essential tools on the right side of the blog)
- waiting a few hours until the new release get pushed to Appslib.
Let me know how it goes.
Downloaded from Arctablet and works fine
Thank you
Carloos
Ruben
50
2011/11/05 - 17:44
Hey CyberSoft, great work mate on this rooted rom.
Works perfect!!
Question though.....can you make this rom support A2SD+??
The internal memory of 250mb makes me wanna kill my tablet, so it would be great to use an ext3/4 partition.
zeke1
51
2011/11/05 - 20:37
I cant install this update, I follow all the instructions, it restarts
and then It gives the following error
Image Enlarger
In this menu I can scroll using the volume changing button
Choosing anything isn't possible (or I haven't found it yet), using the power button isn't working
What can I do to install this custom software?
Gatti
52
2011/11/06 - 11:17
I tried it on Arnova 7 G2, it does not work. Tablet says that he found invalid firmware.
zeke1
53
2011/11/06 - 14:14
Image Enlarger
I redownloaded the image file, and I have put the image file and the zip in the root, and now It's updating fine!
damo
Kingston upon hull, UK
Forum Posts: 243
54
2011/11/06 - 15:18
I have installed the new Arnova firmware for the Android market etc and have noticed that I have been getting device storage is getting low notification, I dont know if this was happening before I installed this I cant remember, anyway I deleted some applications and made sure that the apps that could be moved to the sd card where moved. I presumed that the Arnova 10g2 had 4gb of  internal storage.
Going into storage setting I see the information below:
SD CARD - TOTAL SPACE 14.91 GB
 AVAILABLE SPACE 14.73 GB ( i HAVE 16GB CARD INSTALLED)
NAND FLASH - TOTAL SPACE 2.81GB
       AVAILABLE SPACE 2.19GB
INTERNAL STORAGE - AVAILABLE SPACE 31.81MB
I installed Android system info from the android market to get more info and notice that on the dashboard of the program it reports that the internal memory is MAX 247.92MB and available 31.81mb and the system ram is 512MB and free 100mb.
Maybe I am been stupid but how can I be running out of storage space when I have 4gb internal storage plus a 16gb memory card and the nand flash states 2.19gb available space.
please help
CyberSoft
55
2011/11/06 - 20:26
Hi Ruben thanks a lot, no i can´t, sorry i´m not a advanced user into the kitchen rom world, but i have an app that can help to everybody, i´ll put in htcmania coming soon, so follow the post. Regards...
serge
56
2011/11/07 - 23:45
i update my arnova.. and didnt work!! it crashed...!!! 🙁
i get the arnova start up screen and then strange stripes full with colours?!! what should i do now??
HaroldG
Greater Philadelphia, PA, USA
Forum Posts: 115
57
2011/11/08 - 00:05
Please tell me it wasn't the Philly Newspapers Arnova.  If it was, you're bricked.  Do a warranty return and don't try to root it.  Apparently the firmware is just different enough so that the HTCmania exploit doesn't work.  Bummer, I know.  I was looking forward to root, now I'm looking forward to Archos returning a refurbed tablet before my next business trip!
I am
58
2011/11/08 - 08:25
Is there a posibility to install windows 7,ce or some other windows on this archos 10g2 tablet? Couse in the facturers mainpage is written that this tablet is competible with windows xp,7 and so on..and yet if it is,how can i install it?: )
damo
Forum Posts: 243
59
2011/11/08 - 09:02
No windows 7 or anything before that will not run on Arm chips. The new windows 8 will run on arm chips but not sure if it would be possible on this type of setup. [Image Can Not Be Found]
oldduck
Forum Posts: 21
60
2011/11/08 - 10:11
please help
You have exactly the same problem as I am facing now as the internal storage on my Arnova is only 28MB left, it's hardly to download any more applications.
More issues I am facing with: after download the newest ARCTools from Appslib, Market is running good except:
1.  The default Android Calendar is missing that I used to sync with Google.  Tried Jorte but cannot establish the sync
2. Downloaded and installed GMAIL from Market, Gmail account can be added without problem, but it missed the auto-sync options which require prseeing "Refresh" manually. But the auto-sync from the built-in EMAIL app is working fine.
88 Guest(s)
Devices in use: Desktop (76), Phone (12)
swan12
heftpflaster
