Arnova 10 G2 Custom rom feature requests
ttz642t
Forum Posts: 53
2011/11/20 - 09:32
To whoever built the "Arnova 10 G2 first custom firmware with Android Market and root".
Could the image be built with the "userdata" & "user" partitions swapped ?
Have nearly 3GB of empty rom and only 256MB for apps 🙁
If anybody wants lots of local data storage the sd card is ok for that.
Using Link2SD doesn't help that much as other stuff goes in /data and it fills up quickly.
# cat proc/mtd
dev:    size   erasesize  name
mtd7: 10000000 00004000 "userdata"
mtd9: b4400000 00004000 "user"
IE in the boot process which mounts the partitions swap :
   /dev/block/mtdblock7 with /dev/block/mtdblock9
&  /dev/block/vold/31:9 with /dev/block/vold/31:7
85 Guest(s)
Devices in use: Desktop (78), Phone (7)
swan12
heftpflaster
